Where should i put these tweeters???
Rogers
alright so i won a local comp about a week ago and the prize was some store credit.. anyhow i ended up picking up a set of Kicker Ks13 1/2 tweeters... now... where should i put em? in the top of my doors? A pillars? Dash, right at the bottom of the windshield?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
I vote A Pillars up high to bring your sound stage up.. makes for a better sound.
I would do either of these. If theyre on the dash, dont just lay them there, fiberglass them so they point at you
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
There is no real answer unless you know am SQ guy who knows your car inside and out. And even then he may or may not know the best position because people are different heights, and therefore is either sitting closer of farther away from the dash.
Best advise I can give is to sit in your car how you normally drive and roll the windows all the way up. Then using double sided tape or velcro, mount the tweeters anywhere manageable and take a listen. Even though you will have exposed wires for a little while, it will be well worth it in the end knowing the tweeters sound how you want.
A general rule is to mount the tweeters a couple inches higher than the highest point of the dash (if you're mounting them in the a pillars). Many people get good results firing the tweeters directly at each other. Others use deflection to their advantage but thats hit or miss in each car.
Eclipse cd7000
ill be running these to a channel on my zx200.4 so they will be seeing around 50rms.... i figured id just slap em on the A pillars and flush mount them... but they do also come with angle mounts and surface mounts(which i wont use)..... i could angle them towards the driver and passenger seats or windshield with the angle mounts... but going by what finkster said... ill proble just fire them towards each other.....
this isnt an sq vehicle at all.. its a budget ground pounder... but i do like to listen to rock/metal when on road trips....as far as highs ill be running a Zx200.4 to
1 set of DS 6.5 coaxes in the back dash
1 set of DS 6.5 coaxes in the stock location at the bottom of the doors
1 set of Ks 4" coaxes in the back seat side panels
1 set of KS13 tweets(placement in question)
Im just adding the KS line of speakers to help the highs keep up with the 145+db bass
3 Kinetik Hc2000's
Dual 200amp alts.
rogers loves his kickers xD
and i would do wut finkster said
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Im glad to help but make sure they sound good there before you go and do all that work for nothing. Remember all cars are different. Peace.
Eclipse cd7000
word.. i sure do appreciate you stopin in... ill grab some tape and stick em in the different places and see how they sound... like i said im not into sq... but i dont want them to sound too harsh...
speaking of which.. if they do sound too harsh... would it be better to angle them towards the windshield? i mean i dont expect it to be too awfully bad... im going to be doing half of their rated rms...
3 Kinetik Hc2000's
Dual 200amp alts.
  • Who's Online   0 Members, 0 Anonymous, 964 Guests (See full list)
