calling all mods or steve meade himself..
check your internet security or firewall settings on what sites are allowed or not allowed. I used to have problems with websites that there certificate cant be validated or something like that. Norton security?
2012 GMC SIerra CC
System Build
Headunit--Stock
Sub Amp--DC 2.0k
Subs--2-SA8v2's
Enclosure--Need one made!!
Highs Amp--Sundown SAX-100.4
Front Highs--Rockford Fosgate T2652-S
Rear--Sundown Neo Pro 6.5
XS Power D2400--XS D3400
No Big Three yet!
http://www.youtube.c...ser/raolito1980
change ur ip.
Windows (second option)
- Computer connected directly to the modem
1. Get to a command prompt. (START, run, cmd).
2. Type "ipconfig /release" (without the quotes).
3. Shut down computer.
4. Turn off computer.
5. Turn off all ethernet hubs/switches.
6. Turn off cable/DSL modem.
7. Leave off overnight.
8. Turn everything back on.
Network with Router
1. Log into the router's admin console. (Often http://192.168.1.1/)
2. Release the IP address. (Method varies by router manufacturer)
3. Turn off router, ethernet hubs/switches, and the cable/DSL modem.
4. Leave off overnight.
5. Turn everything back on.
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
In Internet Explorer, go to "TOOLS" "INTERNET OPTIONS" "PRIVACY TAB" (Make sure it is set to medium) then go to "SECUIRTY TAB" and set all 4 zones to "DEFAULT"...
If that works, then it was a setting in IE... If not, then it is more than likely a router issue (possibly a "blocked site" setting or a dns setting)
Agree with David
Comcast has been sucking lately and I have been having problem's getting to known locations on the west coast.
Also check that your host file did not been manipulated.
C:\windows\system32\drivers is where it is at
I have had it happen to me before, you could also try opendns.com, it worked well for me
i thought that picture was a child breastfeeding. I had to read your post to see it was you kissing your gf..
2006 Nissan Z Track.
My Feedback Thread
