Right or Wrong?
Spitfire2k6
Was he Correct?
15 members have voted
  1. 1. Is under-powering detrimental to amps and subs
OK I just off the Phone with the dealer that sold me an amp as i sent it back for repair and he shocked me into disbelief of myself and the SMD forum.
He was telling me that powering a 750W RMS sub or 250W RMS was extremely bad for both the sub and amp...
Now as far as I have read and understand after looking a a lot of topics on this forum under-powering was nowhere near as detrimental to equipment as overpowering...
was he right or what's up
Live life to the full... Then TURN THAT BITCH UP!
The only problem with under powering your sub is that fact that you try to push your amp to hard to achieve more bass in doing so you send a clipped signal that will cause the sub-woofer to overheat and burn up, even if you are not even giving your sub rated power. As long as you set your gain with a oscilloscope or with a DMM you should not have a problem.
Thanks this backs up what I think about the sub but his concern was that even with the gains set correctly the amp could be damaged as its not powerful enough...
Not True.. I have my friend hooked up with a Fosgate P3001 on a pair of subs that can take 600rms each with out any problems.
I had to laugh at the fact someone voted yes. Anyways, NO, underpowering is not detrimental to your equipment. The user is detrimental, not the fact that it is underpowered. If you properly set your gains so there is no clipping, neither the amp or sub will have any problems and will give you a long and happy life.
97 Maxima SE
Bunch of shit going in, check out the build
every fly by nite stereo shop will sell you a amp that most likely not do rated power but says (2000watts) and turn the gain all the way up and most of the time work ok. underpowering a sub is fine as long as you dont clip. i can put my ddm4s(3500each) on some kicker cvrs (500-750 rms maybe) and play fine all day, i did it. but i could make them babys po at will also. what im saying is try to match power of amp to sub or go a lil over its always nice to have headroom cause you will never actually get what amp is rated at in everyday world
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
i was going to laugh but then i saw that 2 people said yes and i simply face-palmed.
underpowering a sub is like having a bench with a 300lbs weight limit and only putting 100lbs in it. just because it can take 750w it doesnt NEED 750w to operate. not only that but the 750w amp is only doing about 300w on music.
I bet he wants to sell you an amp..............or he is just not very knowledgeable...
¿ǝɯɐƃ ǝɥʇ
i guess it could be bad for the amp as it would be running at full to even move the sub but if its a rated amp it should run at full all day every day anyway. but i'd like him to explain why?
you saying that though i went to an audio shop for an amp for my 1000w subs and he tried selling me a 3400w amp that put out 200w rms lol. Glad i did my research before i went. It seems to me most audio shops are retail only these days keeeeeerching $$$$
Shame really as thats what kills the scene i think.
imo a good retail outlet is both very knowledgeable and will offer you good experienced advice. this is where forums like this come into thier own as the people here are both friendly and actually know thier stuff.
hell i'm still learning now :)
  • Who's Online   0 Members, 0 Anonymous, 1024 Guests (See full list)
