Chickens 2002 Caddy, The Hoopty 8 18" Fi Btl + Rockford Fosgate (2) T15k Amps! UPDATES! IPAD AIR 2 In Dash page 335
edit: of course i COULD put a divider in there but it would have to be permanent to be strong enough for what im doing. Theres going to be to much pressure in that little chamber to make something "removable".....
Follow my Tweet (Twitter)
Okay No divider
BUT:
I was thinking about it earlier today. either mount subs then cover them and start glassing OR glass the divider wall to the back wall before you mount it and make brackets on the divider that could bolt to the top and bottom. also just bolt the back wall (with the f/g divider on it) to the back enclosure walls
Oh well your the boss man :D :D :D :D
Edited by JustinT
"IT SOUNDS SLOW MOTION AND STUTTERING"~~~~LOL
2 15" Fi BTLs
7.5 cf box @ 33hz
Sundown SAZ-3500D
Powermaster S3400 & D3100
Iraggi 300a alt
SecondSkin - totally dead
Knu wire
not that master-meade would... but if there was a wiring issue or one blew how would he retrieve the sub then.. i think hes kinda over-limited on space as is. but i love the look, can just imagine those 8 subs banging at each other through the crawl space. while my hearing ceases to exist.
anyways loving this build :)
Edited by TrippiN
Pi x R^2 .....(3.14X81)=254.57in^2
(254.57in^2)x8=20,620.2857in^2
***EDIT***
Xmax on a fully Loaded BTL18 w/ Hixmax option would be 27mm I'm told.
27mm=1.10"
so...If SD=20,620.2857in^2
and xmax is 1.10"...
20,620.2857in^2 X 1.10"=22,724.396in^3
22,724.396/1728=13.15069 CUBIC FEET......OVER 13cubic feet ONE WAY!
SO....
On each ocillation/cycle (full stroke forward and back)....
These 8-18's will move OVER 26cubic feet worth of air to the tune of what ever frequency you like BEST! :D
Or roughly Twice what Steves Tahoe will do :P
OUCH!
Edited by LSN2meBoom916
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
What do you think this is for?
Posted Image
Posted Image
If you guessed T-Faketeen K then you are right! Much easier to move around then the amp itself. I had Two choices of mounting for these amps and one of them didnt involve a spot for the batterys. This leaves me with my only option.
Posted Image
Posted Image
One amp right in front of the other staggered. You should be able to see the LED's on the back amp just fine and it actually leaves a NICE spot for the battery bank.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Keep in mind the boxes are ugly and just made to see where it was all going to fall into place. The amps have angles on them and are of course beautiful so it wont be as bad as these pics. This is just to show you whats on my mind or i should say what my only option is :D
