Long story short:
About 2-3 weeks ago I was not paying attention to volume level and turned my HU up about 5-6 notches past what I set my amps to max out at (before clipping). There was noticable distortion and my sub amp turned off.
Ever since then my externally regulated alt has had a problem reaching its set 15 volts. Kind of like it needs to warm up (which it has never needed to do).
Today I pop my hood to hear a hissing noise coming from my kinteik hc1400.
1. Is this battery shot?
And
2. If so, is that why my alt is having difficulties reaching what I set it to?
I am guessing this is also putting serious strain on the alt ?
Thanks for any help!
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
You are charging at too high of a voltage, that is the only thing that will cause a battery to gas and hiss. I've said it before a million times, BUT 15 volts is TOO HIGH FOR ANY AGM BATTERY and will ruin it.
Thank you all for your responses.
I have a hc800 I guess I will throw under the hood until I can gather funds for a replacement.
Oh and I turned down the voltage to 14.5, I hope my battery can last just a little longer
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
So in regards towards my voltage question, could a bad battery cause the external regulator to act like this? I'm now starting to notice a slight bulge on the top of the battery and there is a tiny crack where the hissing and some fluid (?) Is coming from
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
  • 4 weeks later...
yes since the alt is not seeing any charging it is constantly feeding power.. i would remove that battery does not sound too good!! :ehh: :ehh:
2-10 inch hx2's rfd2110 getting close to 1200 watts rms
PWK enclosure-rear loading folded horn
1-mtx 81000d
1-SAX-100.4
1-alpine h/u
1-set of cdt's euro components
1-set of alpine type's
  • Who's Online   0 Members, 0 Anonymous, 796 Guests (See full list)
