Dont forget to look into Arc Audio...Very Clean subs and not badly priced either..The lower the impedance the more it will be SQ oriented
... i thought it was higher
lower impedance leads to higher thd
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Err whatever.. Meant to say taht if you run at 2 or 4 ohms over 1 ohm you will cleaner input
Team MaxRetribution
Si Vis Pacem Parabellum
gotta keep you in check there buddy, now that you have powers and all lol
i still say ID Max
you could look at TC too but that is... debatable
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
So maybe my amp isn't good for trying to do some SQ stuff?
formerly known as Jaylor Swift
You know taht you can run your amp at 2 or 4ohms right???
The impedance is determined by your sub coils bro
Team MaxRetribution
generally a class AB amp is preferred amongst SQ guys. the sound is better
your amp can sound good yes but you really need to make up your mind about whether or not you want SQ
it is an entirely different game with totally different players.
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
3^ft shared after all displacements tuned to around 33HZ on my amp at 2ohms so they are getting about 300-400 a piece.
I mean they sound good. But it's kinda too much. I usually cruise around with the bass most of the way down.
Well just run 1 12 at 4ohm (assuming you have dual 2s) and put them in about 2cubes with 20-25sq in of port and tune it at about 30-32Hz
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
I'll have to look into this.
Thanks for all the suggestions so far guys. :drinks:
