ok i am in the process of buyinh 3 d2 subs. i can wire them to a 1 ohm load? was more than likely going to get the sa12 from sundown.
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
The lowest you can get without going below 1 ohm is 1.34
EDIT: Check your sig, there's nothing in the quote box...
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
Ninja :)
1.33 is as close as you can get
Series each sub then parallel them together.
each sub would have one positive and one negative hooked together on that sub from one coil to the other. then all the other positive and negative wires would be connected at the amp.
If you want the easy way to figure out impedence of multiple subs in parallel, just do this:
Figure out what each sub will be wired to. D2s would be 4 ohms in series, 1 ohm in parallel. D4s would be 8 or 2. Then, take the impedence of each sub, and divide it by the total number of subs.
Example.
You have 6 dual4 subs. You series the voice coils on each (8 ohm) and parallel all the subs. The final impedence would be 8/6 or 1.33 ohms.
If you parallel them first (2 ohm) then parallel them all you would have 2/6 or .33 ohm.
2 D1s in series then parallel would be 2/2 or 1 ohm.
3 D2s in series then parallel would be 4/3 or 1.33 ohms. In parallel then parallel they would be 1/3 or .33 ohm.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
If you get d1.4s you can wire it like that and come out to .8 or so and I doubt it would matter that close to 1ohm
Who has 1.4's in stock? I hope you understand the difference between DC resistance and AC impedance before you reply. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   1 Member, 0 Anonymous, 4332 Guests (See full list)
