demonstr8 Posted October 24, 2010 Report Posted October 24, 2010 I am wondering how i can stop/prevent that annoying noise! The noise does not get louder when i turn the volume up, but its always audible when the volume is down low and it fluctuates with the engine RPM's. When i un-mount the amp for my highs/mids from the trunk it goes away. Thanks for any info or advice. Charging System Info: 2 yellow tops (1 engine, 1 in trunk) 200a Ohio Gen Alternator I only tell people 1/3 of what im REALLY doin', just so they can HATE ONLY on that third... 2007 Tahoe factory system for now Car Domain Page Lay It Low Forum
KnockinthaStreetzof608 Posted October 24, 2010 Report Posted October 24, 2010 I am wondering how i can stop/prevent that annoying noise! The noise does not get louder when i turn the volume up, but its always audible when the volume is down low and it fluctuates with the engine RPM's. When i un-mount the amp for my highs/mids from the trunk it goes away. Thanks for any info or advice. Charging System Info: 2 yellow tops (1 engine, 1 in trunk) 200a Ohio Gen Alternator you can always try putting deadner on the car hood, might help CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
Cashdollar2009 Posted October 24, 2010 Report Posted October 24, 2010 Ground your RCA's. /thread On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not.
pstone11 Posted October 24, 2010 Report Posted October 24, 2010 Normally it is a grounding issue - try running your head unit ground straight to your battery to see if that helps... If that simple fix dosn't work then you have to tackle the rest of the usual suspects... Power wires/RCA's ran too close together Bad amp ground (on the front stage amp) pinched rca bad rca bad head unit ground (pioneer head units are notorious for this) - ground the outside jacket of the rca to the chassis of the head unit. If nothing works.... keep looking. Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
anubis Posted October 24, 2010 Report Posted October 24, 2010 Normally it is a grounding issue - try running your head unit ground straight to your battery to see if that helps... If that simple fix dosn't work then you have to tackle the rest of the usual suspects...Power wires/RCA's ran too close togetherBad amp ground (on the front stage amp)pinched rcabad rcabad head unit ground (pioneer head units are notorious for this) - ground the outside jacket of the rca to the chassis of the head unit.If nothing works.... keep looking. ^^ word 1998 Monte Carlo Z34 Stock HU but have replacement Stock Highs Stock Electrical BTL 18 sitting naked AP1500D
BanginOnABudget Posted October 24, 2010 Report Posted October 24, 2010 get a 5 dollar metra ground loop insulator. im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!!
pstone11 Posted October 24, 2010 Report Posted October 24, 2010 get a 5 dollar metra ground loop insulator. Ground loop Isolator. That is an unnecessary component if you build a solid system. Quick fix, but not the best fix. Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
demonstr8 Posted October 24, 2010 Author Report Posted October 24, 2010 Normally it is a grounding issue - try running your head unit ground straight to your battery to see if that helps... If that simple fix dosn't work then you have to tackle the rest of the usual suspects... Power wires/RCA's ran too close together Bad amp ground (on the front stage amp) pinched rca bad rca bad head unit ground (pioneer head units are notorious for this) - ground the outside jacket of the rca to the chassis of the head unit. If nothing works.... keep looking. Thanks, i always knew that it had something to do with grounding, i just never knew where to begin or what to try. I'll mess around with some of these idea's and see what happens. I only tell people 1/3 of what im REALLY doin', just so they can HATE ONLY on that third... 2007 Tahoe factory system for now Car Domain Page Lay It Low Forum
