getonerd Posted October 25, 2010 Report Posted October 25, 2010 Quote 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
jconnway Posted October 25, 2010 Author Report Posted October 25, 2010 that looks like some kinda ill diagram but its a little confusing no? Quote Full Pioneer Build 4 Per Door - Front Door Build Up
getonerd Posted October 25, 2010 Report Posted October 25, 2010 the square is an relay Quote 1996 Chevy Tahoe AKA My SQ Hoe Pioneer AVH-X2800BS Precision Power PC.18DS MB Quart NA540.6 Skar Audio RP-2000.1D 55-3210 - 8 Inch MCM AUDIO SELECT Rockville RXM64 Tymphany BC25SC06-04 Kenwood KFC-1795PS
Guest Posted October 25, 2010 Report Posted October 25, 2010 that looks like some kinda ill diagram but its a little confusing no? its a relay. you can buy them at practically any auto parts store like autozone or oreilly's. basically the pin that says 87, you hook up straight to the positive on the battery (fused of course) pin 86 is the remote wire that comes from the headunit pin 85 is a ground, you can hook this up to the battery - if you please. pin 30 connects to all the accessories you want to run like amps or neons or whatever Quote
mbdblue Posted October 25, 2010 Report Posted October 25, 2010 (edited) that looks like some kinda ill diagram but its a little confusing no? 86 would be the remote line coming in from the radio 87 is 12v 85 is ground and 30 is the new lead you would use to turn on all the amps... edit: ah damnit kranny ninja! haha Edited October 25, 2010 by mbdblue Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Alex K Posted October 25, 2010 Report Posted October 25, 2010 I'm running 3 amps and i'm jumping from the mids, to sundown 1, to sundown 2. Works fine for me. Quote 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
bassHZ Posted October 25, 2010 Report Posted October 25, 2010 well i ran 2 amps and an epicenter for 6 months and nothing happend 3 things would be the max amount to run of the turn on lead right now i got 4 things of 2 relays just in case and i got room for upgrade Quote
Guest Posted October 25, 2010 Report Posted October 25, 2010 86 would be the remote line coming in from the radio 87 is 12v 85 is ground and 30 is the new lead you would use to turn on all the amps... edit: ah damnit kranny ninja! haha lol u muddafucka. also to the 2 guys before me, i also run 2 amps and a volt meter off my headunit and its been working fine. Quote
bigaltexas Posted October 25, 2010 Report Posted October 25, 2010 (edited) exactly what they said up there... wherever you first blue one goes to, just put another blue wire in that same slot and run it to the other amp. Edited October 25, 2010 by bigaltexas Quote
dugee81 Posted October 25, 2010 Report Posted October 25, 2010 most head units send a remote signal 200ma MAX, 3 amps is about pulling about most of that if not all. i tried putting 4 on a HU remote wire and power would kind of fluctuate, turn off and on repeatedly. Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
