the square is an relay
1996 Chevy Tahoe
AKA My SQ Hoe
Pioneer AVH-X2800BS
Precision Power PC.18DS
MB Quart NA540.6
Skar Audio RP-2000.1D
55-3210 -  8 Inch MCM AUDIO SELECT
Rockville RXM64
Tymphany BC25SC06-04
Kenwood KFC-1795PS
that looks like some kinda ill diagram but its a little confusing no?
its a relay. you can buy them at practically any auto parts store like autozone or oreilly's.
basically the pin that says 87, you hook up straight to the positive on the battery (fused of course)
pin 86 is the remote wire that comes from the headunit
pin 85 is a ground, you can hook this up to the battery - if you please.
pin 30 connects to all the accessories you want to run like amps or neons or whatever
86 would be the remote line coming in from the radio
87 is 12v
85 is ground
and 30 is the new lead you would use to turn on all the amps...
edit: ah damnit kranny ninja! :dammit: haha
Edited by mbdblue
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
I'm running 3 amps and i'm jumping from the mids, to sundown 1, to sundown 2. Works fine for me.
2006 Nissan Z Track.
My Feedback Thread
well i ran 2 amps and an epicenter for 6 months and nothing happend 3 things would be the max amount to run of the turn on lead right now i got 4 things of 2 relays just in case and i got room for upgrade
87 is 12v
85 is ground
lol u muddafucka.
also to the 2 guys before me, i also run 2 amps and a volt meter off my headunit and its been working fine.
exactly what they said up there... wherever you first blue one goes to, just put another blue wire in that same slot and run it to the other amp.
Edited by bigaltexas
most head units send a remote signal 200ma MAX, 3 amps is about pulling about most of that if not all. i tried putting 4 on a HU remote wire and power would kind of fluctuate, turn off and on repeatedly.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
