I always thought mixing batteries was a bad idea?
Apparently mixing agm and wet cells is bad. Which is why you just replace the wet cell up front with an agm battery before you just "add one to the back".
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
One way to figure this out is look at your fuses on your amps. add that up and see what it comes out too, then think about how much your heat, a/c, lights, etc use and add that to what your amps draw. Think your alt can keep it all charged?
10501650_10203332501847103_1859383749711
Blown
I figure my 75% of my alt is used from factory. Then i used the formula 1900/.7/14.4=(x)/.5 = amps needed, Then subtract Alternator amps. gives me needed draw.
Would it be basically the same to do one large battery instead of 2? like a Hc2400?
Edited by merk_master
hopeful noob
Additional batteries pose more of a load on the alt, give or take ~10 amps.
I had a HC1400 under the hood and 2 hc800's in the rear, some songs would drop me down to the mid 12's. Got rid of my 1400 and now jus have an 800 under the hood and 800 in the back, and I stay around 13.8 on all songs. lowest I've seen was 13.1 for a split second
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
  • Who's Online   0 Members, 0 Anonymous, 3155 Guests (See full list)
