SnowDrifter Posted October 28, 2010 Report Posted October 28, 2010 So as the title suggests... Is one amount of resistance more disireable than another for any reason? This is assuming that the power remains constant regardless of the resistance. So given that power is constant, is there a difference between the resistance of a given subwoofer / wiring configuration? I seem to remeber hearing somewhere that higher resistance is better because it pushes more voltage instead of higher amperage through the speaker, and is easier on the voice coil because of it. Can someone confirm / deny this? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
AMI CUSTOMS Posted October 28, 2010 Report Posted October 28, 2010 In subs it doesn't matter, you select whatever voicecoil config you need to get XX amount of power from amplifier. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
PUNKYOU007 Posted October 28, 2010 Report Posted October 28, 2010 uhhh. The coil config that you want to run is entirely up to you. I mean if your amp is 1 ohm stable then most people would want there final load to be 1 ohm (giving them the most power)....so...depending on how many woofers you are running will depend on what coil you want. Great calc to play around with. now it doesnt show you everything but its probably more than enough for you at this point. Doethepaperboy "Bars of Pain" Doethepaperboy "Hero Remix" C. Arson d(-__-)b beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
SnowDrifter Posted October 28, 2010 Author Report Posted October 28, 2010 Whats bull? Yeah, I would like to know too. It's a legit question. Oh, and I found where I read about it... "Different amp designs with different purposes..High voltage amps have a much higher cost due the parts used in them...high current amps are much cheaper however they are MUCH harder on voice coils due to wiring them down below a half ohm to get the power out of them..." - NDMstang65, audioforum.com Source: just to avoid any issues... "XXVSampson vs JBL 6000GTI." Audio Forum Index. Web. 27 Oct. 2010. <http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?/topic/20/13564.html>. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
AMI CUSTOMS Posted October 28, 2010 Report Posted October 28, 2010 Yeah, I would like to know too. It's a legit question. Oh, and I found where I read about it... "Different amp designs with different purposes..High voltage amps have a much higher cost due the parts used in them...high current amps are much cheaper however they are MUCH harder on voice coils due to wiring them down below a half ohm to get the power out of them..." - NDMstang65, audioforum.com Source: just to avoid any issues... "XXVSampson vs JBL 6000GTI." Audio Forum Index. Web. 27 Oct. 2010. <http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?/topic/20/13564.html>. He is talking about regulated vs unregulated amps. And current does produce heat, but for the most part unregulated amps that are wired down that low are usually for SPL meaning you only play a note for 10-15 sec even 30 sec max and then done. That short amount of time it isn't going to matter that much, or matter to the point of saying one is better then the other. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
moetpoppin Posted October 28, 2010 Report Posted October 28, 2010 just helps you on the amp end of the set up 1 ohm rating is usually higher than the 4 ohm rating on the amp gives you more power, more wiring options when you wire it all together ty TY Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy Party and Bullshit - The Notorious B.I.G. Honest estimate on this truck when it's all done........... 172.3........... Ehh.. U are aware of what 172.3 is, right? yep..... Two Pyle 15"s Build log
skittlesRgood Posted October 28, 2010 Report Posted October 28, 2010 lower ohm load gets you more power. higher ohm load gets you less THD. but no one cares about THD here. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
David Posted October 28, 2010 Report Posted October 28, 2010 Damn beat me skittles... some care most don't.
SnowDrifter Posted October 28, 2010 Author Report Posted October 28, 2010 I'm new to the world of car audio... What is THD? And how can a lower ohm load give more power than a higher ohm load? I know that it is harder for an amp to push the same amount of current through a higher ohm load... But if two different amps are designed to give the same amount of rms power, albeit at different levels of resistance, are the both still different? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
AMI CUSTOMS Posted October 28, 2010 Report Posted October 28, 2010 Ohms law homie Voltage = Current X resistance That is LAW and is always true. So if resistance goes down, current has to go up to keep the same voltage. How regulated amps work is they regulate the voltage to match the resistance so you get the same power at 1 ohm or 8 ohms. You see? TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
