4Ω vs 2Ω vs 1Ω etc.....
Ohms law homie
Voltage = Current X resistance
That is LAW and is always true. So if resistance goes down, current has to go up to keep the same voltage. How regulated amps work is they regulate the voltage to match the resistance so you get the same power at 1 ohm or 8 ohms. You see?
Very clearly, thanks!
I'm new to the world of car audio... What is THD? And how can a lower ohm load give more power than a higher ohm load? I know that it is harder for an amp to push the same amount of current through a higher ohm load... But if two different amps are designed to give the same amount of rms power, albeit at different levels of resistance, are the both still different?
THD-
Total harmonic distortion is a measure of the how much a given audio device may distort a signal through the introduction of added harmonics or overtones. These figures are usually given as percentages. THD figures below approximately 1% are inaudible to most people. However, distortion is a cumulative phenomenon, so that if a receiver, equalizer, signal processor, crossover, and amplifier are all rated at "no greater than 1%THD", together, they could produce 5%THD, which may well be noticeable in the perceived sound.
Taken from here- http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know-about-car-audio/
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
In you can understand terms,
THD means the amount of gain you add to the signal that is being played once it distorts in percentage. So if you have 10% THD then you will be making alot of power, BUT chances are the woofers won't last long with the level of power on them, POWER is what blows a woofer, NOT distortion. Power creats distortion because you are clipping the signal, a square wave makes more power then a sin wave.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Ohms law homie
well a regulated amp isnt that good. itll work for 1ohm and 2ohm but past that they will drop off like any amp.
amps can be made to do more power at 2ohm than 1ohm but the vast majority will do more power at a lower ohm load. and as for "why?" well its less resistance, if one car has less drag itll go faster correct? same shit here. less opposition/resistance to the flow of electricity. but more current means more heat in the amp and heat is the #1 killer of amps.
I have tested JL and Memphis amps, different model, they did same power at 1 ohm or 4 ohm or any in between. I was using a generalized point when I said 1 or 8 ohm, but in tested I have seen the same on regulated 1-4 ohm.
Evo X build log
well... a clipped signal doesnt make more power just because its clipped. the amp is pushing the signal past a useable point but still adding power. the reason a clipped signal blows a speaker is because the speaker actually moves less and has a pause at the top and bottom of its throw. this means that the speaker isnt moving air around the coil like it should and isnt cooling properly. then it transforms into a slinky.
All that you just said they have a word for, it is called over excursion....LOL
Evo X build log
ic. i was going off of the RF constant power amps. i never read up on JL stuff lol.
And that is funny cuz I haven't ran or tested a rf amp since the punch 75, that was one amp that ran very damn hot!!!
Evo X build log
well acording to the "pro" (shop owner) near me better off buying higer end amp that put out same power at 2ohm then the cheaper at 1..aparently 2ohms sounds nicer then 1..but idunno bass to me all sounds the same the l7 sounds just as good as w7 to me LOL hope didnt offend any jl fans :peepwall:
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
  • Who's Online   0 Members, 0 Anonymous, 443 Guests (See full list)
