DC Sound Lab
Neo's can be used for daily music and burps...You just have to have a way to properly move the air away from the Motor...Neo is much stronger then ferrite but it breaks down due to heat....If you can get the motor properly cooled then i would go Neo if not then just go Ferrite :D
i know neos hate heat...but...
how does one keep it kooled
NoFearX18 said:
trainman0978 said:
dc98hoe...what are you hitting now and what gear are you running again??
my best score is 154.4 sealed on the dash at 38hz im running 4 xl 18s in a way too small box off of 2 DD m4s strapped at .7 rising to 4.6 and giving me 5400 watts. im going to mess with my port today to try and get my rise down
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
:orly3: Neos dont like daily? :rofl:
I've been running my DC neos at .25 daily on the AB 1100.1. They take it like a champ and sound great! The DC neos were designed to be a daily driver with spl side effects.
In my application...I burp at volume 26-27...I also play music at volume 26-27 lol They are far superior in cooling over the lvl 5 and as a result play longer and harder. I've yet to stink them up and I've worked em real hard for sure :woot:
Nick I'd go for the Neos :good:
The design of the motor is how you keep it cool. Sitting a coil that can heat up to 400degree next to something that loses strength at 130degrees or less don't seem like a very good idea.
Just what I think? But why does my opinion matter, I'm nobody.
air conditioning
place some dry ice in the box, run the a/c really high all the time and hope the cold air gets into the box, dont run so much power, extra heatsink, water cooling, umm thats all i cant think of
most are relatively ineffective
just replace the woofers every 2 years or so (which is done by most anyway so it shouldnt be an issue)
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Have you played with a neo driver? I can only comment on the DC neos as that is all I've played with but there is no and I mean no issue with cooling in this design.
I was still waiting for awesome numbers... :peepwall:
Just fucking with you bro...
I love it when people talk out their ass... :popcorn:
that statement was meant to be as in i wanna be able to do big numbers and do demos as well...haha
and whos talking out of their ass??
NoFearX18 said:
I don't have to play with a neo driver to know how things work. The sub works, I can see that. Just don't see how it does for long periods of time without losing strength.
Its all in the design. While I agree the biggest down fall to neo was the loss of strength due to heat, things have been changing and growing and cooling has improved 100%
AS stated the cooling of this neo driver is far superior than any ferrite motor DC makes. (Straight from Rusty himself)
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
