will a 4 channel amp work?
hello,
im upgrading my shaker 500 system in my 2007 mustang. anyways i was looking at adding an amp new 6x8s and new 8" subs in the doors. the hifonics hfi100.4 amp is a 4 channel amp that does 100 watts at 4ohms and 200 watts at 2ohms. now can i get like 100 watt at 4ohm 6x8s on 2 of the channels and 2 200watt at 2ohm subs on the other 4 channels?
2007 mustang
Boyo avn701d
hifonics bxi2610
2 olm 2415s
hifonics 100.4
2 infinity 6x8s
2 kicker comp cvt 8s
If you are going to be making fiberglass panels for the 8's you might as well glass some 6.5" components in and not use 6x8"s. Also, there are better amp you can get instead of hifonics. And also, if you use 2 of the channels on 6x8"s or 6.5"s you will only have 2 channels left, not 4. But yes, it can work.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
You might want to look into a better amplifier than that, I've read that the HFI series doesn't do rated
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
so basslova,
if i find another 4 channel amp like something i described, i can run 2 channels at 2ohms and 2 channels at 4 ohms?.
i know that there are better amps out there but i have a couple of there subs and an amp and am pretty happy. there not the greatest but pretty good considering there price
2007 mustang
Boyo avn701d
hifonics bxi2610
2 olm 2415s
hifonics 100.4
2 infinity 6x8s
so basslova,
Yeah, for sure, just make sure the pair with the same ohm load share the same circuit (one isn't on one of the front channels and the other on the rear) otherwise you will have problems with the gain. So yeah, just do say the two 4 ohm speakers on the front channels and the two 2 ohm ones on the rear.
  • Who's Online   0 Members, 0 Anonymous, 7625 Guests (See full list)
