Ok so I have 1 15inch Kicker L7 in 4.2 ported box. I have the sub wired at two ohms. The amp that was previously powering it was a Hifonics BXI Brutus 2607d amplifier. I'm not sure why but it broke and wouldn't power my sub anymore. So, I got the AQ 1200D which I regret because it only puts out 800 watts at two ohms. I should have got something that put 1000 watts at two ohms. Anyways, I still hooked it up but my sub hits way differently then it did with the Hifonics. It's not nearly as loud and doesn't hit the mids AT ALL. It's so much weaker. And the sub is hitting weird. I guess I'll make a video of it tomorrow so you can see what I am talking about.
Edit: Is there a better amp that puts out true 1000 watts at 2 ohms?
Edited by cichlidfort
2008 Chevy Impala (undercover cop style)
Setup in the makings
No experience with AQ amps, but check your wiring and polarity perhaps? Check any filters, RCA's, etc. Maybe your sub's fried? Any other amps to test it on?
POTATO!
you're not going to notice 200w difference. aq underrated anyways and it's probably doing close to 1k anyway.
Edited by Alex K
2006 Nissan Z Track.
My Feedback Thread
my guess is your crossovers are set wrong.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
take a picture of the amp settings
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
Going from a 2600w amp to a 1200w amp and there's a difference? Oh noes! But its probably your crossover settings. Like Chris said, take a CLEAR picture of the knobs on the side and post it here
Edited by Kranny
Check the resistance of your voicecoils. Maybe you're getting a weird load cuz one of the coils is burned
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
If your hitting mids on a sub something is wrong in the first place and not adjusted properly, and yes you won't have the same output as the hifonics which has more power than the AQ does @2ohms. LPF should be set at 75hz to 80hz and subsonic set to just a bit under your box tuning. The links i posted above are rated 1000w @2ohms.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
