2 subs sharing same port
For instance, port width is 5 inches and needs to be 43 long. The front of the box would have the 5" wide port, then, once it hit the back, would it split off into 2 2.5" sections for each side? Does each side need to be 43, or does it split into half?
2006 Nissan Z Track.
My Feedback Thread
heres what i got.. lookin for the good box builders to chime in here lol.
and with a design like this, what are the # common port walls?
My Feedback Thread
x2 I've never understood how to do this exactly so I just stick a piece in the middle of the port and make it basically two boxes...
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Alpine KTP-445 Power Pack
-Polk Audio db6501 (front components)
-Polk Audio db651 (back coaxials)
-2 RE Audio SEX12D4s
-Cadence F1200-1D
- Custom box tuned to 33Hz
- Kinetik HC1400
- 50 ft2 of Audio Technix sound deadner
- Big 3
My photography page
you need a 90' triangle at the end of the mouth where the ports meet or you are gonna have cancelation like none other. think about the air and sound pressure meeting face to face from each chamber, its gonna be horrible. i'd say get 2 45' degree pieces of sonotubne, glue em together, and have your 90' piece. keep in mind the mouth side of your port (ex. 5 inches) you want to maintain that 2.5" of port per chamber so you are looking at either 4" or 6" pvc or sonotube.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
Combined would need to be 43, so at the split you half it, think of it like one box for one sub, would the port need to 43 long? Hope that helps.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
OK AMI, so when you say that the length splits, does that mean once it hits the back, which in this case would be 25" back, then to get to the rest of 43, do I add 18 to both side, or 9?
My Feedback Thread
My first thought is 9, but it would depend on if you are going to put some kind of divider on that back wall to split the ports?
Evo X build log
dont knock my paint skills lol.
1. is one box with a terrible design
2. is optimal for sound.
3. will be alost as good as 2, but you wont be able to see the port, if thats what you're going for.
the way i look at it, if you want ports in the middle, go with round ports, if not, go with a square port on the side, unless you want to do a serious design.
oh, and when you put a piece in the middle of the ports it DOES change it from one box to 2 boxes, the subs are not sharing the same chamber or port, therefore, 2 seperate boxes, combined at the port wall, to form one box, with 2 seperate chambers and ports.
  • Who's Online   0 Members, 0 Anonymous, 1116 Guests (See full list)
