Hi all,
New to this forum and From the UK
I have myself a saz-1500D powering 4 jbls at them moment but Ive got two DC level 5 18's ready to go in once I have the power to get them moving.
The lv 5's I have are dual 0.7ohm... plan is to run 4 saz-1500D's, strapped @ 1.4ohm per pair.
Ive been thinking about bringing the build forward and starting next month instead of january/febuary but I would only be using two saz-1500D's untill I got the cash for another two...
My question is would I be ok running the amps at 0.35 ohm each? My power supply is not as strong as your big american cars, the car is a lupo 1.4tdi, I Have a 120a alternator, Ill be using one XS power d3100 for now.
Or would I be safer to use them 1.4ohm per amp? what sort of power do they do at 1.4ohm?
Thanks guys.
I think running them below 1 ohm load will void the warranty, and with the juice you have I would def. NOT run them lower than 1 ohm
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
2 of those amps on one of those batteries?
those amps will eat that battery, spit it out, and still drop your voltage to "something is going up in smoke" levels.
Am i reading correctly. Is he saying 4 SAZ-1500 off a 120A alt and 1 battery..... Dont do that lol
2011 Subaru WRX
Rockford Fosgate T1000-4AD
(2) Sets of Rockford Fosgate T3 6.5 Components
In the works:
Rockford Fosgate T2500-1bdcp
(2)DC Audio 12" XLM2
hhmmmmm yeh what everone else has said ........... don't do it.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i wouldnt do it, maybe for a burp or something like that if you had the electrical. You need a h/o alt and another 3100D
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Thanks guys Ill just be running them at 1.4ohm each untill I get the other two which will see 0.7ohm each.
Power supply wont be staying at 1 d3100 and 120a alt.... ill be adding another d3100 and 210a alt with external regulator. Been told one these xs power d3100 can power 3k....???
Even with those two batts and the new alt i still won´t wire them that low, voltage is gonna drop anyways, only way you can use them under 1 ohm it´s having a very steady voltage, i wouldn´t wire them below 0.7 ohms each (if you can have that config) with the kind of voltage you´ll have.
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
