that audioque 2200 requires 1/0 power and ground
you need to run 1/0 for both
whats your electrical like?
my electrical is shit right now im considering switching it from .5 ohms to 2 ohms until i can get a new alt bat and 0 gauge
you would need some decent electrical to run it that low so i would def change it to 2 ohms
what size was that fuse?
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Just run 1/0 with the big 3 upgrade, a 2nd battery in back and some quality fuse holders that require terminals on the ends so there is no chance of melting it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
its very simple, you are drawing way too much current through that small of wire, you need to upgrade to 1/0 with big 3 done and a second battery wouldnt hurt. Running an amp like that under those conditions will fry it.
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
ok im getting 0 gauge this week for sure and if i have any extra 0 gauge im doing the big 3
Currently in a build
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
Pioneer AVH-P2300 (next purchase)
High output alt 150 amps
i cant believe you were running 8 gauge power wire on that amp.
8 gauge ground and 4 gauge power i know ive been meaning to upgrade that for along time
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
you can spend about 100 bucks at knukonceptz for a great wiring kit, i think i paid 110 for my GFs kit
Team_DC-Derrick's Youtube
Team DC Audio
yea big three upgrade in 1/0 and a second battery ran in parallel with 1/0 to the back battery with a good fuse inbetween the power
and 1/0 to the amp power AND ground with a good clean ground and a the right size fuse inbetween the amp and battery with i think would be 200 amp
the 2200d is fully stable to 1 ohm i wouldnt run it a .5 unless i had VERY good electrical
if it were me id run it at two ohms or recone to D2 and wire it down to 1 ohm but its your choice
hit up knukonceptz for some 1/0 wire and darvex for terminals and fuse holders
  • Who's Online   1 Member, 0 Anonymous, 781 Guests (See full list)
