alphasig293 Posted December 9, 2010 Report Share Posted December 9, 2010 So other than the amp getting hot, how you liking it? Quote 2005 Lariat F-150 On 30 inch DUBS 6 Crossfire XS-V2 18's 2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4 12 - 6.5 Crescendo mids and 4 Crescendo supertweets SMD 340 alt, Mechman 270 alt 7 NSB 170 batterys Link to comment Share on other sites More sharing options...
bobonit Posted December 9, 2010 Report Share Posted December 9, 2010 No because they were getting hot b4 subs were hooked up Where is it mounted? Is it above the muffler or something? If no subs are hooked up, it should not be producing heat. If you want to test that theory, disconnect the amp (power and ground) and leave it mounted where it is. See if it gets hot. If it does, its just ambient heat and nothing to do with the amp at all. Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log Link to comment Share on other sites More sharing options...
fritosaregood Posted December 9, 2010 Report Share Posted December 9, 2010 Were the amps hooked up to power/ground, remote, and rcas but no subs. and you drove around with the amps on with no subs connected? That could be the problem. Im not exactly sure why but that can hurt amps. Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
sundownz Posted December 9, 2010 Report Share Posted December 9, 2010 Were the amps hooked up to power/ground, remote, and rcas but no subs. and you drove around with the amps on with no subs connected? That could be the problem. Im not exactly sure why but that can hurt amps. If signal goes in the amp is still making voltage -- this can actually damage the output section as it can climb too high with no load. Quote - Jacob Fuller - Owner, Sundown Audio - Sundown Audio on FACEBOOK - Please DO NOT PM ME -- use my email address -- [email protected] Link to comment Share on other sites More sharing options...
tsuch20 Posted December 10, 2010 Author Report Share Posted December 10, 2010 well it hasnt shut off or anything just gets hot? what should i do Quote 2011 Subaru WRX Rockford Fosgate T1000-4AD (2) Sets of Rockford Fosgate T3 6.5 Components In the works: Rockford Fosgate T2500-1bdcp (2)DC Audio 12" XLM2 Link to comment Share on other sites More sharing options...
sundownz Posted December 10, 2010 Report Share Posted December 10, 2010 Don't do anything -- just don't run it with no load connected If your amp is not shutting off it's okay thermally. Quote - Jacob Fuller - Owner, Sundown Audio - Sundown Audio on FACEBOOK - Please DO NOT PM ME -- use my email address -- [email protected] Link to comment Share on other sites More sharing options...
FYI-Future-Star Posted December 10, 2010 Report Share Posted December 10, 2010 try putting in some fans maybe that will help Quote Team O.B.M '97 Tahoe Build after the new year!!! Kenwood kdc-x794/16gig android tablet 6 sets of Crescendo ccx65s 2 18s 2 Sundown saz 4500s 2 Sundown sax 100.4 1 Mechman SMD spec 360a 4 XS d1400s My Feed Back http://www.stevemead...showtopic=44841 ub Link to comment Share on other sites More sharing options...
FYI-Future-Star Posted December 10, 2010 Report Share Posted December 10, 2010 (edited) a few like this should help some http://www.parts-exp...tnumber=259-122 Edited December 10, 2010 by FYI-Future-Star Quote Team O.B.M '97 Tahoe Build after the new year!!! Kenwood kdc-x794/16gig android tablet 6 sets of Crescendo ccx65s 2 18s 2 Sundown saz 4500s 2 Sundown sax 100.4 1 Mechman SMD spec 360a 4 XS d1400s My Feed Back http://www.stevemead...showtopic=44841 ub Link to comment Share on other sites More sharing options...
n8ball2013 Posted December 10, 2010 Report Share Posted December 10, 2010 If the amp is not shutting off it's fine -- it is not unusual for a high powered amp that is putting out high power to be warm the man was spoken. I dont think you'll need more info than that Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Rainman215 Posted December 10, 2010 Report Share Posted December 10, 2010 Yeah i know its december but in october i drove to maryland -3 hours... it was a good 80-90 that day... amp cut out as i was driving i pulled over and it was sizzling. I didnt take the outside temerperature/play time into consideration and was just slamming it. And just make sure your ohm load is correct. I thought I had my saz3500 wired at 1 ohm ... but i didnt. Ive had no problems other then that with the sundown (which was my own fault) Quote My 02 Accord Wall Build 2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500 Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters DC Power 270xp --- 4 XS Power D1200s | 1 D5100R Link to comment Share on other sites More sharing options...
