Jagraj7870 Posted December 9, 2010 Author Report Posted December 9, 2010 not the guy to answer that one for ya lol. But id say so. Ask kranny or skittles. they know everything lol alright thanks - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
94retta(219) Posted December 9, 2010 Report Posted December 9, 2010 do like the guy in that vid did. have one door open in a car with your window open... areo ports do change everything tho. BUILD LOG
siccostyle Posted December 9, 2010 Report Posted December 9, 2010 There is another thread with some opinions about your build. I don't know if what is said about your build will help or not. I cant remember which thread it is though. I think it had something to do with clean power. I cant really remember. If someone else has seen that thread maybe they can chime in or if I can find it I will post the link for you. 01 2dr ExploderBuild log2 18" DC Level 6's (M3's)DC 10k5 XS d3100's, DC 390 alt100' shok ofc cable Team ShokTEAM SUB SONIC ADDICTION
Guest Posted December 9, 2010 Report Posted December 9, 2010 not the guy to answer that one for ya lol. But id say so. Ask kranny or skittles. they know everything im flattered lol but i dont know everything. im only 18 and i still want to learn more
Jagraj7870 Posted December 9, 2010 Author Report Posted December 9, 2010 im sorry but you should be doign higher then a 145.6 with that much power. If you want to do a decent hairtrick now no one beside someone who owns the exactl vehicle you have will be able to tell you but my suggestion is either port back sub up or port and sub back. either way i'd have the port along the bottom with about 15-18 sq inches of port per cube with about 6-6.5 cubes so wat ur saying is face the subwoofer up, and have the port facing the tail gate? in a 6-6.5 cubic box but the sub recommends a 7 cubic box and how much should it be tuned to? - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
94retta(219) Posted December 9, 2010 Report Posted December 9, 2010 just for shits and gigs invert the bitch. That should do somethin, and it takes 10min to do it at no cost! BUILD LOG
OldsBoomer Posted December 9, 2010 Report Posted December 9, 2010 im sorry but you should be doign higher then a 145.6 with that much power. If you want to do a decent hairtrick now no one beside someone who owns the exactl vehicle you have will be able to tell you but my suggestion is either port back sub up or port and sub back. either way i'd have the port along the bottom with about 15-18 sq inches of port per cube with about 6-6.5 cubes so wat ur saying is face the subwoofer up, and have the port facing the tail gate? in a 6-6.5 cubic box but the sub recommends a 7 cubic box and how much should it be tuned to? Yea pretty much the onyl problem with the SMD is the mounting depth maybe try haveing the port on the driver side that will probably give you your best results and no the SMD is a small enclosure sub but seeing as i've talked to nick( one of the designer of it) you'll be fine a a 6.5-7 cube box but like i said i think form 6-6.5 will be good for you tuned from anywhere from 28-33 hz that'll help you out with the frequencies that a hairtrick usually happens in. Suburban Coming Soon
Alex K Posted December 9, 2010 Report Posted December 9, 2010 not the guy to answer that one for ya lol. But id say so. Ask kranny or skittles. they know everything im flattered lol but i dont know everything. im only 18 and i still want to learn more kranny, you are the master of everyones questions. 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
Jagraj7870 Posted December 9, 2010 Author Report Posted December 9, 2010 im sorry but you should be doign higher then a 145.6 with that much power. If you want to do a decent hairtrick now no one beside someone who owns the exactl vehicle you have will be able to tell you but my suggestion is either port back sub up or port and sub back. either way i'd have the port along the bottom with about 15-18 sq inches of port per cube with about 6-6.5 cubes so wat ur saying is face the subwoofer up, and have the port facing the tail gate? in a 6-6.5 cubic box but the sub recommends a 7 cubic box and how much should it be tuned to? Yea pretty much the onyl problem with the SMD is the mounting depth maybe try haveing the port on the driver side that will probably give you your best results and no the SMD is a small enclosure sub but seeing as i've talked to nick( one of the designer of it) you'll be fine a a 6.5-7 cube box but like i said i think form 6-6.5 will be good for you tuned from anywhere from 28-33 hz that'll help you out with the frequencies that a hairtrick usually happens in. alright so i should go with a rectangular port idea on the drivers side and not a aeroport? - 2 SMDs 1 Kicker WarhorseSound System Build Log: http://www.stevemeadedesigns.com/board/topic/120796-2-18s-in-jeep-wrangler-jk-w-kicker-amplifiers/Air Bag Build Log: http://www.stevemeadedesigns.com/board/topic/166437-jeep-wrangler-bagdj10k-build/https://www.facebook.com/teammayzn
Guest Posted December 9, 2010 Report Posted December 9, 2010 not the guy to answer that one for ya lol. But id say so. Ask kranny or skittles. they know everything im flattered lol but i dont know everything. im only 18 and i still want to learn more kranny, you are the master of everyones questions. lol i try my best
