Posted (edited)
ok so my system has been working fine till today. when i turn up the volume to a certain point the bass with cut out to half way. this never happend before i checked fuses they looked good but i replaced them anyways. im running 2 kicker zx2500.1 and 2 10"kicker solo x any ideas?
Edited by MarioB
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
check grounds?
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
check grounds?
Not yet i didnt think of it till i put it all back together. ima take it apart tomorrow and check all the wiring i thought maybe it was my fuses beacuse i had little ones on it so i thought i wasnt getting enough power to the amps. it just started today to havent had any problems. my volts havent dropped below 13.
are you using AGU (glass) fuses? if so, the solders will fail before the fuse itself...check them.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
check your batteries voltage as well as all the grounds... Check each battery individually... Let us know what it is...
i checked all batts. they are all in the mid 13's. i then check my fuses under the hood BAM! found a blown fuse on one of my 1/0ga runs to the back now the question is how can this 300amp ANG fuse blow like that? still check all the grounds? i checked it this morning right before work so i didnt have much time to check all grounds.
did that solve the problem? i had a similar problem and it was a bad rca
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I think it is a perfect time to bring that car up here and make some changes.:peepwall:
DO work son! make it LOUD!
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Any banks near by and a good get away hahaha.
Ya it solved the problem
