08 Tahoe- 2 FI SP4 18s- 2 AQ 3500s
imo i think 14 cubes is going to be too big for you, when i had my 5s in 13 cubes they didnt like it i kept blowing them. ive heard them in 10 and it gets loud off of 8k
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
that is one stunning chevy. im not one for lowered trucks but after seeing this one i am a fan. are you going to redo your mids and highs ? if so what do you have planed for that ?
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
wow your hoe looks clean as! nice work :)
id be putting an SD8k on the level 5s for sure, i had one on an RE MT and the coil was fine running daily at about 3ohm after rise (6-7kw ish) didnt like it too much when i lowered the tuning and cranked some C&S though... ripped the spider :(
2 levels 5s should take 8k all day every day
^^^ clicky pics for build logs ^^^
  • Who's Online   2 Members, 0 Anonymous, 985 Guests (See full list)
