please answer all the questions in any post you get.... thanks.... also, here is the page with the calculator on it http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator-updated-310/
ok then with out taking sub displacement and with 3 ports your looking at just under 35 hz
with 11 ports and those dimensions and no baffle or bracing and 3/4 in thick wood, your looking at around 76 hz
can i add you as a friend so when im ready i can hit u up
Have to say mixing sub sizes unless cut off freq are done well will not sound the best and mixing sub sizes in the same enclosure is definitely a no no you should only ever use matching speakers in a common enclosure.
I am sure with the help you can get from here you will end up with a nice sounding system.
JJ
Alpine 9855r
2 x DC AUDIO LVL 4 18"
2 x Hybrid Audio Technologies L8
2 X Hybrid Audio Technologies L3
2 X Hybrid Audio Technologies L1 PRO
1 x SAZ 4500D
2 X SAX 50.4
AudioControl Matrix + AudioControl Epicentre 160
8 X hawker genesis deep cycle batteries
As said, you can't have a box with multiple sub sizes unless you are looking for disaster. You'll get the subs interfering with eachother and will not only sound like shit, but very possibly damage your equipment. If the 15s are separated that should be fine for them, but 12s and 10s in the same box, unless they are separated, is bad.
do you have any bracing for that box? those subs will tear that wood to shit :peepwall:
2006 Nissan Z Track.
My Feedback Thread
