LOLs!!!!!!
Take the back cover off the amp, depending what kind of inputs are used on the amp, you should be able to poke a small pin or nail thru the back of the rca inputs on the amp and push the center pin back out.
Edited by Audiofanaticz
If it's a hollow pin (a lot of the cheap ones are) then take a very thin self-tapping screw and gently twist it into the pin until it bites then pull it out.
I get this quite a lot with amps I'm repairing... ugh.
10.x volts fo' life!
what does your putting entirely too much stress on an rca wire have to do with how much it costs?
...*facepalm*
try what these guys said to get that pin out and make damn sure you don't make this mistake again.
Edited by sanitarium
Okay I tried everything!! Took the amp apart well back piece doesn't have a hole to push it out ... 3 different kind if tapes ! A needle almost damn near stabbed my eye cuss it it broke n hit the shit outa nose . Any ideas
take a needle, head of a small nail, etc and dab it in a light amount of some super glue...hold it to the end of the stuck piece for about a min, then pull it out...this is how I fix em...but don't use alot or you could clog it up
...*facepalm*
This..............I have a set of Walmart Schoche RCA's that I have had for 7 years, it has been in my vehicles it has been in friends vehicles and it still works great
¿ǝɯɐƃ ǝɥʇ
Will do
Next post will be how to remove a 16 penny nail from my rca input cause I super glued in there. :D
Try the screw method. That thing cant be stuck in there that bad.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
