just finished mounting the subs and the port... sounds like the box is too damn big.... i remeasured and im looking at almost 10 cubes.. so i need to do some shrinking down to 5 or 6 then more tunning and hopefully it will work... it sounded better in a box in my trunk then it does currently ...
almost like its free air= too much space
is it sealed off around the box yet? if not thats the issue
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
you remeasured, did you take into account the bracing and port after you remeasured?
and like n8 said, if you didnt seal off the box from behind it, its probably getting into your trunk and shit and it has to pressurize the whole car instead of just the front cabin
Team_DC-Derrick's Youtube
Team DC Audio
x2 on everything, but damn, not even as loud as his old box in the trunk??? something´s wrong there!
the inside cracks were done with fiberglass resin and the outside of it was done with construction adhesive...
beleive me its sealed..
ive done a box before for 2 15 inch mtx 9500s and it sounded the same as this wall
after i cut that box smaller resealed it and adjusted the port it pounded...
only thing is adjust the size of a walled up box is a bit harder..
yes i did even still i just fell that the enclosure is too big...
the recommended ported is 3.5 to a sub.... should i add that together since i have 2.. or put it around 5 to be safe..
this is my fist wall so im still learning as i go...
i think you misunderstood by sealing it off... were talking about sealing it to the pillar outside of the box so no air goes behind the box, so it pressurizes a smaller area
spray foam around the box to keep air from going behind it.. should sound better
Team DC Audio
No he didnt mean if your box was sealed,he meant is your wall sealed (there are no gaps on the top/bottom/or either side of the wall that will let air get behind the wall).Understand?
Member of Team 808
Member of Team North East Spl
  • Who's Online   0 Members, 0 Anonymous, 1189 Guests (See full list)
