I thiiiiiiink the DD Z motors are bolted although I'm not 100% sure.
But yeah, the glue they use for the slugs is pretty much the strongest thing ever. Either it's a faulty glue joint or you're doing something pretty awful to the subs.
That said, I've seen a couple of subs-up installs where the box has been dropped and the motor has fallen off the top plate...
10.x volts fo' life!
lol if 10k is to much power for him a DDz isn't for him either
but the cooling fins are bolted down not the neo itself
that gives a pretty good look inside the motor
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Mmmmmmmm sexxxy
2010 Civic SI sedan: Crystal Black Pearl
All stock.
if your offroading alot and have heavy woofers you might wanna look into a sub facing upwards configuration. specailly if it jolts around alot.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
That is what i've been doing, but it limits installation options sometimes...
Wenn_du_weinst - re-read my 10K quote please.
Hammerdown... 1%
Mmmmmmmm sexxxy
the left one weighs over 100 pounds
http://www.stevemeadedesigns.com/board/topic/90529-smd-15-an-in-depth-look/
Looks like ~7KW is "ok" on an SMD.. so I might be looking more into this direction :)
Hammerdown... 1%
  • 1 month later...
Mmmmmmmm sexxxy
What the hell is that left one?
6" coil
-BriAn
12" RD Audio Alpha v2 with PAP softparts. 3"ww 8layer al vc
Recoil RED 1000.1
Audiopipe 0 gauge wiring kit
Kinetik hc600
5 Farad Capacitor
2.26cuft slot ported box tuned to 30hz
(bbp6 says its 37hz 12volt says 30hz)
  • Who's Online   0 Members, 0 Anonymous, 3102 Guests (See full list)
