Bakerman Posted January 8, 2011 Report Posted January 8, 2011 Gotta set of mid drivers that are rated at 100w RMS. My amp is puttin out 150w RMS at 4ohms, and 300w RMS at 2ohms. Would it be safe to wire it to 2ohms, or hell, even 4ohms? Quote
speedball1978 Posted January 8, 2011 Report Posted January 8, 2011 if you do that you'll be kissing those speakers goodbye Quote
Bakerman Posted January 8, 2011 Author Report Posted January 8, 2011 I correct myself...the speakers are 250w RMS, so at 2ohms, i would be 50w over power, but at 4ohms, im underpowered...is it safe to go just 50w over RMS? I know you're not supposed to, but in all honesty, will it seriously fry the speakers? Quote
MrSkippyJ Posted January 8, 2011 Report Posted January 8, 2011 (edited) i'm curious how you are going to change the impedance load without changing the number of drivers. Also, what type of speakers are you talking about? that always helps. Edited January 8, 2011 by shkibbybop Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Bakerman Posted January 8, 2011 Author Report Posted January 8, 2011 (edited) i'm curious how you are going to change the impedance load without changing the number of drivers. Also, what type of speakers are you talking about? that always helps. Its a 4channel, and I have two right drivers, and two left all at 4ohms. If i use the 4 ohms, one driver to each output. If I go with 2ohms, two drivers to one output, wired in parallell. Brings it down to 2ohms, and I have two free channels for more drivers. And the speakers I'm using are hifonics zxi6.5c Edited January 8, 2011 by BakermanINC Quote
TheBetterMethod Posted January 8, 2011 Report Posted January 8, 2011 You'll probably blow them. Turn the gain way down and never listen to them above a comfortable, distortionless level.\ If you do that, you'll probably be alright. But the speakers won't handle the full power. Quote 2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3 The first build>>> http://www.stevemead...-outback-build/ 140.9 @ 36hz Sealed on dash! REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
speedball1978 Posted January 8, 2011 Report Posted January 8, 2011 then you might be okay at 2 ohm.. but run them at 4 just to be safe, if you run em at 2 ohm you can set the gain down some Quote
MrSkippyJ Posted January 8, 2011 Report Posted January 8, 2011 i'm curious how you are going to change the impedance load without changing the number of drivers. Also, what type of speakers are you talking about? that always helps. Its a 4channel, and I have two right drivers, and two left all at 4ohms. If i use the 4 ohms, one driver to each output. If I go with 2ohms, two drivers to one output, wired in parallell. Brings it down to 2ohms, and I have two free channels for more drivers. And the speakers I'm using are hifonics zxi6.5c THat won't actually change anything. 300 watts/2 speakers is still 150 watts a speaker. and the speakers you said you are using are a component set, are you talking about using the whole set or just the 6.5 woofer? The total power handling for the set is 100 watts, the power handling for each speaker is lower. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Bakerman Posted January 8, 2011 Author Report Posted January 8, 2011 i'm curious how you are going to change the impedance load without changing the number of drivers. Also, what type of speakers are you talking about? that always helps. Its a 4channel, and I have two right drivers, and two left all at 4ohms. If i use the 4 ohms, one driver to each output. If I go with 2ohms, two drivers to one output, wired in parallell. Brings it down to 2ohms, and I have two free channels for more drivers. And the speakers I'm using are hifonics zxi6.5c THat won't actually change anything. 300 watts/2 speakers is still 150 watts a speaker. and the speakers you said you are using are a component set, are you talking about using the whole set or just the 6.5 woofer? The total power handling for the set is 100 watts, the power handling for each speaker is lower. I'm using the whole component set, but they wire into an electric XO...the XO only has one input, and it is at 4ohms...so it only has 1 set of wires from the amp... Quote
Team808 Posted January 8, 2011 Report Posted January 8, 2011 If you have 2 speakers on 1 channel ,and it will be a 2 ohm load ,and at 2 ohms your amp will put out 300 watts.Then each speaker will be getting 150 watts .So weather you use 2 channels at 2 ohms or the 4 channels at 4 ohms,you will still get the same amount of power to each speaker. An amp runs cooler and more efficient at 4 ohms than 2 ohms.Also keep this in mind ,if you have a class a/b amp its probably 60% efficient .So at 100 watts you really are only getting 60 ,and thats probably rated at 14.4 volts ,and your car wont stay at that voltage so that will bring down the power of the amp also.Hope this helps . Quote Member of Team 808 Member of Team North East Spl
