I currently have my amplifier grounded to the seat bracket but not sure where to move it to. I heard that you could ground your secondary battery from the main battery, but can I use this same concept to ground my amp. I can't find a good spot to ground my amp unless I drill a hole through my floor and ground to the bottom of the car. The car is a 92 Ford Mustang. I can hear the noise from the exhaust, I'm pretty sure its coming from that ground spot
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
Best ground is to the frame of the vehicle, or directly to a battery negative post if you can reach it.
^x2
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
could also mount it to your rear strut tower
R.I.P!
(Nov-29-2009)
92 explorer
current build
The frame or batt is best, but sometimes are hard to get to. I've got mine on my rear strut.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
Yep ground to the rear strut tower or do a run from your front batt neg.
Make sure to grind the paint off first if you do it to the tower.
For the post above me, unibody cars have no frame.
Edited by Rebel4055
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
This question is asked daily, you could maybe try searching the forums for the answer.
Grand Cherokee
Team Backwoods Bumpers
DC 15" Level 3's /w 4 Coils
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Audiopipe 1500.1D @ 14.4v
Clarion Equalizer
Knuconeptz Kollosus 0ga
Knuconpetz Kollosus 4ga
Coming Soon: 270xp / xs1200
Frame or post just like all the others said above^
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
When I ground my ground to the frame or by the strut bar I always manage to get a spot that gathers up moist then with in a hlf yer it gets all rusty
<script language='JavaScript' src='http://www.rockfordfosgate.com/downloads/banner_link.asp?p_id=18'></script>
