how to run an amp without a remote turn on
Okay...
One thing
NATE IS A MOD...
HE CAN SEE THAT YOURE REPORTING HIM...
TWO,You CAN use a toggle switch and flip on the amp when you need to.
Nate was just saying, that its better to save up and do it right than to fry your 4 wheeler,With some toggle swicth shit.
well my point is all i needed was the info on if i could run the amp with the jumper. i didnt need for you guys to call my set up ghetto or any of the other stuff that was said. the way i have the wire ran it is double fused so the worst i would have to worry about is a dead battery.
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Toggle switch don't have to b ghetto. A lot of people use them in cars to turn off amps fast. If its just a 4 wheeler I wouldn't put any kind of good head unit in it. Mud just will tear it up. An mp3 player will work but might not have enough output voltage to run the amp. U also won't b able to tweak the sound unless u got a high end player with eq. I don't know exact #, but 4wheelers usually don't make too much power so don't go too big on amp or batt won't recharge enough. Btw, a lot of people in s.florida put little systems on them to have some tunes while trail riding.
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
Audiocontrol Epic-160
Pioneer DVD head unit
thank you bro. it only gonna be 200 to 400 watts of power. and i have a samsung p3. it has 3 custom eqs you can use along with bass bost and 3d sound i think its called dsne or something like that. and i think itll have the voltage because ive ran my computer and my mp3 into a power acoustik amp the same way and it worked. only difference was i everything wired up right i just plugged in the rcas elsewhere
The toggle switch will work perfect for what you want to do. As far as running the amp with an mp3 player, i have a 4 channel hooked up in the bed of my truck with 4 6x9s and run it with my ipod whenever I want some music while I am working. I wouldnt call it ghetto at all, I would call it working with whatcha got.
"working with what you got" thats exactly what i was trying to say earlier. you know for me being 16 im lucky to have what i got. and awesome who needs a boom box when youve got an amp, mp3 player, and some 6x9s lol
Okay...
One thing
NATE IS A MOD...
well my point is all i needed was the info on if i could run the amp with the jumper. i didnt ask for my set up to be called ghetto or any of the other stuff that was said. the way i have the wire ran it is double fused so the worst i would have to worry about is a dead battery.
Running the amp with a Jumper is fine, I like the idea of power tapping the fuse for the headlights or any other switched 12v fuse/power source. BUT do it properly. Don't wrap the wire around the leg of the fuse or jam it into the fuse panel etc... buy a power tap wire device/connector. they sell them at autozone, and they wont spread apart the contacts inside the fuse panel. (this could cause connection problems)
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
LMAO at this. I don't say much, but damn.
There is absolutely no reason for him to get a new deck in this case, nothing ghetto about it. Usually, MP3 players have too much voltage out of the headphone jack, so be careful of going full tilt into the amp, I'll will input clip. If you have access to a multi-meter and some junk RCA ends you can test the actual voltage and kind of remember where to limit the volume. You dont want 20 volts going into the amp. :) An O-scope would be best, but I'm doubtful you have access to one. Anyways, good luck.
Clovis Custom Audio 559-392-3600
96 Silverado Single Cab
2-DD9515's Cut-through
1-DDSE Amp
Stock electrical and a couple small stingers, LOL
thanks for wishing me luck, ill be sure to check it out so i don't clip.
  • Who's Online   0 Members, 0 Anonymous, 4709 Guests (See full list)
