help with wiring screen.
I have a litton mobilevu that is mounted in my dash but I'm trying to think of the best thing to wire it into so I don't have to turn it off and on everytime my truck is started and shut off. What would be a good thing to wire to?
"WHOEVER SAID MONEY CAN'T BUY HAPPINESS MUST OF BEEN BROKE"
does it have an ignition 12 volt constant and ground?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Wire it to the ignition or Remote cable :)
With everything on my remote now would I just need a relay for that? I was thinking remote but dnt want a whole bunch of stuff running off it.
If you have a remote, run it to the HU then everything else from the one on the HU
Live life to the full... Then TURN THAT BITCH UP!
12v Constant running through a relay controlled by the remote. a relay will draw like, 150 milliamps tops. It won't add much more strain on your remote. Or just use the ignition acc. unless you have a low current ignition, then same thing, use a relay.
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
  • Who's Online   1 Member, 0 Anonymous, 1706 Guests (See full list)
