XS Power
Yep that's normal. That resting voltage "soundzright" lol
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
you can train your batts to rest higher. 12.8 is fine as far as im concerned.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Depending upon what charger you were using and what rates (amperage and voltage) it was charging at you will get different readings. If you are charging at a low amperage (5 amps or under) then the charger may say it is fully charged, but you actually did not get a deep charge on the cells. On the other side of it if you charge at too high of an amperage (20amps or higher), then you will get a quick charge that doesn't fully charge the cells. Both of these situations can cause the battery to not hold the voltage as good.
Your battery sounds like it will be fine. Just keep it charged up until you install it and you shouldn't have any problems.
I charged it at 7 amps at 14.5 to 14.7 volts. It took a little while to charge up out of the box about 40 minutes. It didn't stay in full charge for much more than 10 minutes the rest of the time was in the last stage. I kept it on float for about an hour as well.Thanks for the advice.
If it is being stored indoors then you should be good for a few weeks before it starts to get to the 12.6V range, then charge it back up. I would just put it on the charger and leave it, but that may not be a good idea depending on the charger you have.
  • Who's Online   0 Members, 0 Anonymous, 802 Guests (See full list)
