How To Properly Fuse Amps and Rear Batteries
Did it Help
34 members have voted
  1. 1. Did this Guide Help You?
    • Yes - Thanks :D
    • No - Still Confused :( (Post Why So I Can Help)
    • Didn't Need the Help (Already Know How)
    • I am stupid! Why am I here?
very bad things....I did say usually
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
So I have the big 3 and using 4 gauge for power, I want to upgrade to 0 AWG, I can use the 4 gauge I currently have as ground?
I am going to run 2 Punch 1000's or an AQ2200.
Pontiac Grand Prix GT
400a Mean Machine alt.
EIGHT DD 12''s on a DDz2
DD vo 8''s,6''s,5.25''s&tweets
Norfolk, VA
http://www.youtube.c...ser/ovnorfolkva
https://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishova
http://www.stevemead...__fromsearch__1[/color]
YOu gonna need to upgrade that wire under the hood..
if you upgrade the positive and not the negative then you're wasting money and time...electrons flow from negative to positive, and will only see the smallest wire in the circuit...if you have 4/0 all around with a 10 gauge ground it will be like having 10 gauge all around...you will have a bottleneck of current at the ground.
Principal
the diagram reads that its optional evcept for high wattage systems? Do I still need it for 2000 - 2500 ? I do have the battery in back grounded to the chasis.
Norfolk, VA
yes...I would upgrade to the largest cable you can afford no matter how much power you're consuming.
Principal
Not exactly, if you are running directly off the alternator(power and ground) to your battery bank/amplifiers, then the chassis grounds doesn't make any difference.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
from the batteries and the amps they do
Principal
You can run power and ground direct off the alternator and never touch the chassis ground, batteries and amps wired direct to the charging source via a large diameter cable is far superior to using a lesser conductive metal like a vehicle chassis.
Evo X build log
absolutely!! I agree with that 110%...but power and ground still need to be the same size.
Principal
  • Who's Online   0 Members, 0 Anonymous, 1263 Guests (See full list)
