Question about dimming lights
Hey all. I was playing my tunes at night with the car on and the lights dim quite a bit.( I know I should remedy that ) I was parked btw. Having said that I turn off my car cause it was wasting gas and I noticed my lights didn't dim near as much. The volume was the same on the stereo. I am curious as to why that is. Anyone know?
when the car is on it uses the alternator for power and when its off it uses the battery
''The Darkest Souls Are Not Those Wich Choose To Exist Within The Hell Of The Abyss, But Those Wich Choose To Break Free From The Abyss And Move Silently Amoung Us''
Chances are you're dropping to the 12's or high 11v range..which is where your battery is going to rest so it's not going to be dropping it from 14-12 so you don't notice the dim as much.
My alt runs at 15.1 so dropping to 14 is a slight dim for me...
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Ah....That makes sense. I thought there would be less dimming with the car running as there is more juice but there is also more of a voltage drop when running an amp that draws more than what the alternator can produce. Gotcha and thanks for the info.
Also I was thinking of getting another battery to help with this issue of dimming but won't it still dim as it will still drop from 14 to 12. I mean if the alt is 14.4 volts and a battery is 12 then there will always be a voltage drop no matter how many batteries you have. Am on the right track here?
im sorry guy but...
stupid. you think the car doesnt use the batteries while the car is on?
yes, exactly. the light are already dimmer being at 12v.
all that pus the car its self draws power to run the fuel pump, injection, computer, heater, ect.
except the alt is running and supplying more power to run everything.
No, the current drawn by your amp is FIRST provided by your alternator, when the current exceeds the rating of your alt, it falls back on the battery to back it up, hence the voltage drop. Adding a second battery will increase the current handling capability of your car. if it is an AGM deep cycle battery, it will charge and discharge extremely quickly, which will eliminate dimming from voltage drop.
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
Ok awesome. I appreciate the responses/answers. It really helps me to understand the dynamics of what's going on. So the more current I have (car on) the less of a voltage drop I will have. Is that right?
What system, car, and any upgrade? YOu light are dimming because you systme drawing more power?
  • Who's Online   0 Members, 0 Anonymous, 1656 Guests (See full list)
