basically. strapping allows you to have one master amp. and one slave amp that follows the master
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
so let me get this rite wen u strapp 2 amps together you just set 1 amp and other 1 follow's
yep. say you strap two AQ3500's.
each amp is stable at 1 ohm, so strapped, they are stable at 2 ohm.
and when you set 1 amp, the second amp will follow whatever the first one does.
AS LONG AS YOU SET THEM MASTER/SLAVE.
under construction
u hate c-fizzy?
by strapping your amps you can do 4 amps per one sub - hell you could do 8 amps per sub with quad coils
**edit didnt proof read
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
Quad coil could do 8 amps. Pair per coil.
Hammerdown... 1%
more power....
seriously, were the posts above for real?
SMD SuperSeller VerifiedJbondoXJames Shields
far as what I know:
strapping = more power & less time tuning amps trying to get the to match out put
two 3500 wat amps strapped together = one 7000 amp
I could be wrong (if i am tell me!!!!)
Edited by Dj_Scarface
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
You right, ease of tuning.
thanks
I have:
pioneer AVH-P6500
Crescendo 1100.4
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
My Build
