JoshAndrews Posted February 4, 2011 Report Posted February 4, 2011 I recently started running the big 3, but I didn't have enough terminals so I only ran the positive to the alternator. My question is, why are the 2 grounds necessary to upgrade? It just doesn't really make sense to me. Also, will I notice a change when I upgrade the two grounds? I noticed quite a big difference when I upgraded the positive to 1/0, but voltage still drops quite bad at idle. Will the grounds help this? Thanks for any info. Team Flex Issues '96 Mazda B4000 HeadUnit:Pioneer DEH-4200UB Mids:4 Pioneer 6x8s Tweets:4 Pioneer Tweeters, 2 Polk Audio Tweeters Subs:3 15" American Bass HD 15s; Wall in progress. Amplifier:Hifonics BXi 1608(temporary) Stock Alt Stock Battery 1/0 Power, Ground, Big 3.
BlitZ Posted February 4, 2011 Report Posted February 4, 2011 yes, the grounds will definitely make a difference... old set up Alpine IDA-X305S Memphis M-Class 4x6" Focal Access 6.5" Hifonics BRZ2100.1D 2x DC Audio Lvl 4 15's Big 3, DR44 Alt, Yellow Top http://www.youtube.com/user/SicNoma003
osamio Posted February 4, 2011 Report Posted February 4, 2011 I recently started running the big 3, but I didn't have enough terminals so I only ran the positive to the alternator. My question is, why are the 2 grounds necessary to upgrade? It just doesn't really make sense to me. Also, will I notice a change when I upgrade the two grounds? I noticed quite a big difference when I upgraded the positive to 1/0, but voltage still drops quite bad at idle. Will the grounds help this? Thanks for any info. ALL THREEE must be done. If it didn't make a difference why would EVERYONE do it? We're not all stupid But think of it like this, if you have 3 hoses, all connected, the first one is a FIRE HOSE, and the other two are tiny garden hoses....Will water flow well? 2009 Cobalt LT Pioneer Headunit 2x Pioneer 6 1/2 (stock amp) 2x Pioneer 1" tweeters (stock amp) 2x Pioneer 6x9 (stock amp 4x Pioneer 6 1/2 Pioneer GM-6400F Soundstream DTR 1700 R.I.P 2x Champion series PRO 12" subs 0 AWG Big 3, Stinger SP1700 battery To come: New or repaired DTR!!
FaTbOy911 Posted February 4, 2011 Report Posted February 4, 2011 YES U NEED TO DO IT Had an estimate of 6400 for an alpine/clarion setup dealer said it "should" hit around 160db with the custom boxes he was going to make for me..doubtful with so much area to move but, budget is way below that any ideas on cheaper brands for that kind of Spl setup? really didnt want to try any Boss or soundstorm, thinking Quantum figure around $150 per speaker "$1800 total" and $1700 to power it, first actual big setup for the van. New MEMPHIS CAR AUDIO build 4 15s Memphis C3 2 xs power D3100 1 xs power d3400 custom fiberglass door pannel and lots more My Build
rubbernutz1 Posted February 4, 2011 Report Posted February 4, 2011 as far as u gitting voltage drop at idle that will happen usually cus alternators have a certain turn on rpm where they start putting out more amps and volts. and that rpm is almost always higher than idle speed in a stock alt. but yeah the big3 will help out definately
michigancapri92 Posted February 4, 2011 Report Posted February 4, 2011 you need to to the grounds because the grounds are just as if not MORE important than the power, the electronics in your car is one big circuit, the power you put out has to be brought back, if you are pushing out so much power and you cant return it to send it out again you have voltage drop Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
