I think you just want to get louder..why dont you save yourself some money and just build a larger enclosure with some good bracing n resin the indide and do some sound deadening to the trunk and cabin. Maybe some deadener and then sound barrier on top of it. Mdf isnt too expensive and sound deadener will only set you back a few hundred if you take advantage of a sale promotion. Better than sepending 1200 just for a new amp. Also whenever your batteries die on you think about getting all same brand and same group size batteries..different batteries of different group size and brand cycling charge between them can cut down on battery life for all of them. Just tryna help out
You need trunk space to get groceries and shit...bitches love groceries
Had a Cres 3500D on my 2 12" ZV4s @ 1ohm w/ 3 Batts to wear them in, then swapped out to a 5500D and they're loving it. Mind you I've got a mighty big enclosure for what I have too but theres never been a problem :unknw:
2013 Mitsubishi Outlander ZJ
(2) Sundown Audio ZV4 12" , 6cuft box @ 37Hz (Playing 28Hz-55Hz, Peak 43Hz)
(1) Crescendo BC5500D
(2) Alpine SPR-60C (Front)
(2) Alpine SPR-60 (Rear)
(1) OA OAK75 4Ch (p.o.s)
(1) Fullriver HC55 12v Batt (Front)
(2) Fullriver HC110 12v Batts (Rear)
KnuKonceptz Wiring - 0awg Fluro Orange Power, Black Ground Cables
CarBuilders Sound Deadener
PB 148.6dB 43Hz Sealed
Before removal of stock front batt
....big 3 cube box..12 inch zv4 ..5000d..on good voltage...nuff said here my friends lol
2004 Chevy Trailblazer LT
Walled- 10.5 cubes net tuned 33Hz
2-15 inch AA Team subs D2
Americanbass- 750.1
1 yellowtop under the hood , 4 c&d 88ah batteries in rear
mechman-270
pioneer headunit-4200UB
4 soundqubed supertweeters
phoenix gold 2 channel
back up camera
stinger volt meter
22 years old and still have alot to learn..lets get it
  • 3 months later...
So if 2.25 is ideal for a 12" how about a 15" on a saz-3500? Trying to see if I can get 2 15s in my mag without walling.
05 dodge magnum rt
DEH-80PRS
Rockford fosgate T600.4
st200 tweeters
Sundown Neo Pro 6.5 v2's
2 Saz-3500v2- Toolmaker dual 1/0 inputs
2 Sundown ZV4 12" D1
1/0 Sky High Power wire OFC
3 XS D3100- Toolmaker battery terminals
Mechman 320 Amp Alt
Smd Voltmeter
KnuKoncept 1/0 OFC
My (4) Zv4 18s came in yesterday. Im running 2 at the moment on an NS1. 2 of them are laughing at my NS1. Ive been beating the shiz out of them and they barely get warm and havent smelled a coil.
Define "laughing at". I hate when people say that. It means nothing. How do you know you're not a cooter-hair away from a bad day? Rant over lol.
Dude around here had two Zv.4 12's on an NS-1, and the surround was dimpling at full tilt. I'd say that's pretty near limits. Enclosure definitely plays into that though obviously.
Edited by gckless
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
  • 1 month later...
Has anyone had any issues with the spiders on these subs? I pulled mine out yesterday to just look it over and when I lift the cone about 3/8"-1/2" small 1/4" long tears open in the peaks of the ridges of the spider, it's only about a month and a half old and it's only been on a RF T2500.1bdcp, it's in a ported enclosure just under 2.5cubes tuned to 32hz and I've used the subsonic filter and broke it in according to what sundown had said? What gives with this thing?
Nic watts is throwing a 5k to each of his an his zv4s are nasty!! My brother also had a single zv4 15" and he put 2 IA20.1 @.25 each daily an it LOVED it!!
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
  • 5 months later...
I was wondering about your box size because with my two dual 2 zv4 18s in my box that's 11 cube with a port thats a bit under two cube with the use of my DD z1a at half ohm, within 30 seconds of a song the subs cook fast......is the box to big ? Got a 300 amp spx alt and 5 diehard platinums and one under the hood the box was tuned to 34hz if i new how to post pictures i would post a pic of my box design.
  • Who's Online   0 Members, 0 Anonymous, 1162 Guests (See full list)
