Seqioua- MAJOR REBUILD [3 stereo integrity ht 18s 3:1 4th c-pillar wall][3 audiopipe acpl 1500.1d]
04 Toyota Seqioua Budget Wall 4 SUNDOWN E15's
Since Ive joined this forum ive been fasinated with all the great build logs on here. You might see alot of things in my build that look some what similar as this is my first big build so im just trying what i have seen done. This will be a budget build, It will be a long going build as i will buy everything piece by piece. Im always working on something car audio related so there will be tons of pictures.
Current Equipment:
Head Unit- Pioneer touch screen navi
Components- kicker
Wire- 1/0 Knukonceptz with BIG 3
Sub amp- Soundstream Ta1.3000d
Components amp- NONE
Subs- (x2) Alpine Type R 15's
Planned Equipment:
Head Unit- Pioneer AppRadio 3
Components- Soundstream
Wire- x2 runs 2/0 welding cable
Components Amp- Soundstream Ta4.720
Subs- (x4) Sundown E Series 15's
Heres The Car
4EA2449A-6911-499F-81F1-71AB41CEB024_zps
A944EF3C-2094-4960-B9C0-6DA55F634C28_zps
The Enclosure
Went back and forth between designs for this box. Its going to be a "C" pillar wall. I finally decided on a design. here it is.
Ok well we and my friends have been working like crazy on the box. I wanna try to atleast have the box built and in the car before my subs get here.
Got all the wood best thing about my job is i get free mdf because they use it to protect the sheets of other wood in the palet. B776ADFB-67C3-4EDE-9EE4-15C5750B3591_zps
Getting all the pieces cut. thank god that i have a table saw
B05688B5-22AF-4DB2-BEF2-7F47A3CA6AFF_zps
Glue glue glue. For the longest time a use to just squirt glue on and hope the pressure would spread it evenly. Seen someone on here spreading it around evenly and thought it was a great idea. Although this was you end up using a ton of glue thats okay becuase you cant ever be too strong. You may notice there is a brown coating on one side of all the mdf thats just the way we get it at woork for some reason. We scuffed if up so the glue would adhear better.
9B3DD981-70AA-4B01-AEFD-3D1B801F4AE6_zps
EAB00A31-E951-4154-AA07-B6521FBA3A25_zps
After using like 2 bottle on just the front baffle i decided that i needed some more
062D73D6-D810-4991-BFEE-8BE1BFE05274_zps
Getting the rest of the pieces glued on. i had to be careful so the seems all lined up right in the end.
7765182D-1FC2-4482-89AB-11CF87A7A204_zps
ED7AC628-40ED-4A1B-BD23-C46C20AB6A67_zps
okay well heres what i came of with and figures if would be the strongest bond on the corners and give more surface area of the glue to bond.
066D0BE1-7C0E-4A2E-BB18-9E0062B364DE_zps
DBB26162-D144-43E8-B890-FBEA765FF1C6_zps
mocking it up to make sure everything fits. holy hell this thing is going to be heavy
207455FB-1E1E-4D10-812E-407DA449D8A9_zps
more glue glue glue glue. every seam covered in glue.
40FF073F-706F-4F76-B23D-B4DF6EA8D217_zps
and then this happened.
4AD4FC69-094F-4C0F-A72E-3E572E205BF5_zps
7FF262FC-BA2E-4623-A654-A06248278C1B_zps
its coming together
6B2C2BD9-D868-4DAD-9020-DBEED4EA73CD_zps
F3FEA864-EEC2-41BE-A4F2-750F016B092B_zps
got all the sides glued and screwed together. and the front baffle screw on thing this is huge
CB643936-6A88-4BDF-887D-85BC09788880_zps
8AF1DF2C-6417-4386-93C7-0507F6471398_zps
heres a better picture of the way the seams fit togther. very strong.
57FD0CB0-881B-4BC9-B2A0-589C8016298B_zps
556D0282-E1B6-4C44-81EE-5F5ECAD917AD_zps
And as you all know a box can never be built too strong. I dont wanna have to go in a redo anthing on this box so im gonna build it as strong as i possibly can. i had some angle iron sitting around in the garadge
7A2C5C4D-B71C-467B-8E59-9743D115A6F8_zps
found some big flat washers at home depot i figured would be great and use 1 1/4" screws to fasten in. I also used some locktite behind in just incase. Over buliding is the key.
49C3FD15-98BF-4D4D-9FAA-7D2041034316_zps
311E0D2C-673D-4CB9-9F8E-EA7B9262BD66_zps
random picture
A7F8D554-576D-430A-BD57-527FECB93A5A_zps
Tuned in! Lookin good so far
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Looks good man. Bringing it by tomorrow?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
I've been waiting to see somebody do a wall with the e-15s, can't wait to see how this turns out, keep up the good work!
will do. should be an intresting build. i was tossed between so many different budget subs out there from soundqubed, obsidian, sterointegrity. but after my buddy bought two of the sa 12's and i heard just how great they sounded and the quality of build. and from all my research the e 15's have the same quality
cant wait for these puppies to come in so pumped.
05786D96-66A8-4EA8-9AA1-8E67F230CDDC_zps
