Can someone check my wiring diagram?
So I put together this diagram and am going to wire my suburban accordingly. As this is the largest install I have done, I just want someone to look over my wiring digram to make sure I'm not going to make an easily avoidable problem. Critique away.
-If its loud, fast, outrageous, or all of the above, chances are i'll think its awesome.
-"No way he's OCD." -said none of the people that know me ever.
04' Suburban "Lucifer" A.K.A #Lucii (Under Construction)
4 10s on 4kW in 6cu net @~28hz
/////Alpine
Crescendo
KnuKoncepts
Optima
SHCA
Build Thread
92' JDM 325i "Stella" ~Going for sale to build a 350+hp E30~
Gutted pipes
96,000 OG KM's (59,000 mi)
-System Removed-
1 10 on 1kW
89' Gen 3 Honda Prelude SI AWS "Odis"
Bone Stock
Possibly going to stance it
Was planning on going to chassis, but I can go to battery, it will be right beside it. I only did it that way because my thought was 2 grounds > 1ground.
/////Alpine
Crescendo
KnuKoncepts
Optima
SHCA
Build Thread
Gutted pipes
-System Removed-
1 10 on 1kW
Bone Stock
One thing I see as an issue is the 300a fuses on the front to back cables... You should fuse for the size on the wire run not just put a fuse there... As in the length of cable might only be able to carry 200 amps, then you would fuse just below that so the fuse will blow and not just sit there....
Pioneer AVHX-5800BHS
Alt CES 200/270+
Good point, is there a way calculate it, it's knuconcepts flex cable, and sky high for grounds. Not sure how long exactly the length will be yet, my best guess is roughly 17ft runs.
/////Alpine
Crescendo
KnuKoncepts
Optima
SHCA
Build Thread
Gutted pipes
-System Removed-
1 10 on 1kW
Bone Stock
This thread is a bit old now, but I just wanted to post my final numbers, based on the calculator provided (thanks "Neverknowsbest" a good link right there.) @18' runs there will be 4 250a fuses in place of the 4 300a fuses during my 1/0 runs, sound resonable? amps will also be grounded to the rear battery vs chassis (Thanks TaylorFade). Both batteries will be brand new Yellowtops because XS is impossible to get in Canada, sound like I should be set to start running some cable?
/////Alpine
Crescendo
KnuKoncepts
Optima
SHCA
Build Thread
Gutted pipes
-System Removed-
1 10 on 1kW
Bone Stock
250 amp fuses are still too big, you want to fuse for your current demands as long as it does not exceed your wires rating.
The smaller the better.
  • Who's Online   1 Member, 0 Anonymous, 828 Guests (See full list)
