DC Sound Lab
DC lvl 5 m3 15 in a 4th order
How big should I make the sealed side in a fourth order bandpass for a 15" lvl 5 m3? There will be four 15's in the enclosure
Pioneer 80PRS
4 Scan Speak discovery 4" full rage
2 Ampere Audio 6.5 Comp sets
3 Singer 370 Hairpin's
1 Odyssey g78/34-P1500
6 DieHard Platinum Marine g31
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Lots of welding lead & SkyHigh
Team DC AUDIO
depends on power, these subs technically arent designed for 4th orders
Actaully the M3 models the best out of all the other lvl 5s for a 4th. But sealed sizes will vary based on what you are trying to achieve and desired sealed resonant. However I will share what I have ran and tested. sealed per of 2.05cu will yield a seal resonant of 46hz. Which should give you a start point
  • Like (+1 Rep) 2
Thank you for they replies . I will be using 4 DC 5k's @ 1 ohm each.
Pioneer 80PRS
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Team DC AUDIO
I had two 10k's, I was rising to 6.6 ohms ( like 4900 watts total @ 33hz) and losing a ton of power. I am in the process of redoing the enclosure ( making sealed side bigger and opening up the port ) but my point is, I probably wont be seeing anywhere near 5k per sub.
Pioneer 80PRS
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Team DC AUDIO
And here we go
Why are your posts always so negative in the DC section. If you're going to be an ass just stay out of this section.
NoFearX18 said:
trainman0978 said:
What does make a sub designed for a fourth
Typically an efficiency bandwidth product that is within an acceptable range. Fs divided by Qes should be between a range of 40-100. High Qts can also be another good sign that the sub is suited for a sealed or 4th order bandpass enclosure.
  • Who's Online   0 Members, 0 Anonymous, 1406 Guests (See full list)
