high pitched noise
Jhunt94
Alright so pretty much ever since I've had my 80PRS I've had a small high pitched whine in my system, but it's been so faint that you couldn't really hear it.
I figured that it had to do with my hu ground so this past weekend I tore apart my system to replace the ground. Now the high pitched noise is far more
noticeable. Just to see if it was my rca I took a spare and ran it across the seat, and the noise is still there. Oddly when I was unplugging the rcas, for
every rca I unplugged the noise got louder. Also Idk if this has anything to do with it, but when I was disconnecting everything, I had power off the headunit,
and a 1.5 rca jumper I had going to my PAC LC-1 caught on fire.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
I agree with this statement above, pioneer have issues with their pico fuses blowing in the headunit, when this happens it lifts the grounds.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
I did try grounding the rca jacks after it happened, and it offered no solution. I still don't know how the rca caught on fire, but I'm wondering if some kind of current travelling through the rca friend something in the hu.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
No idea why an RCA would (or could) start on fire.
But hot swapping RCAs is a big no-go. Especially with Pioneer. Google pico fuse noise.
Static drops are my bag.
idk how it could have happened either, there was no power on the headunit bc I have already unplugged the wiring harness.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Your RCA ground is a better ground than your amp ground apparently.
Pioneer 80PRS
lol, very good point shade tree.. wow you have a really terrible ground when your amp is using your rca jacks as a last resort
but that rca wasn't hooked to the amp, but that being said, I haven't checked my ground recently. It's tied to the frame, and I usually check it periodically to see if it has loosened. I want to say that while I was doing this I had removed power from my distro block, so there wasn't any power on the amps either, but I can't remember.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
I had a similar issue with my 80prs was sending voltage thru rcas even when hu and amps where off. Sounds like a defective hu. I got warranty on mine and got a new one and no more issues. Hope you get it figured out
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
  • Who's Online   1 Member, 0 Anonymous, 952 Guests (See full list)
