ok so i have a 1200 rms amp, i only have 4ga running to it and dont feel like buying 0ga so can i double the 4ga? the battery is already in the back. Also if i build a ported box with tube ports can i have the ports in the back of the box and the sub in the front? some one told me its a bad idea cause the air wont circulate in the box?? it will just go through the ports??
Edited by doughboi916
Not sure what ur askin here bro.
Might need to clarify some of it.
"Double the 4ga"...going to the one 1200rms amp? or add a 4ga for another amp?
or you saying add another amp to the existing 4ga?
Very unclear here.
Also, port should either be same side as subs or port back and subs 90 degress off as in sub up port back or sub back port up. This is to avoid cancellation.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
ok, sorry about not being clear, i was at work and in a rush, so i have 1 amp thats supposed to be powered by 0 ga wire but im only running 4ga and i have a whole 25foot spool left of 4ga, can i double the 4ga wire to the amp instead of replacing it with 0ga??
i understand what you're saying. i'd rather double up the 4ga versus only using one run of it .......... sort of sucks to have multiple runs of a smaller wire when you can just get one big wire but do what you have to do.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Guest MegaloManiac
a single run of 4awg is fine for 1200watts no need to double it.
however if you are thinking two 4 awg = one 1/0 awg youd be wrong. I belive 3 runs of 4 = 1 run of 1/0
Almost.
2-4ga cables = 1-2ga wire
2-2ga wires = 1-1ga
2-1ga wires = 1-0ga if it's "really" what it says it is, in any case...
Some cable will be over/under marked.
If you had 3 overkill 4ga that would be close to = 1/0ga.
In either case, Megalo is correct on the NOT needing more cable, 1200rms is fine off 4ga.
what 1200watt amp says it "requires" 1/0ga is my Q?
If you want to and have the cable u'd be fine doubleing the cable up and running another one but actually GETTING IT INTO THE AMP...cleanly might be an issue.
Maybe consider a reducer.
Almost.
2-2ga wires = 1-1ga
I think thats correct from what I always heard. like wiring two 4 ohm coils parallel making it 2 ohms, same type of deal for wire. But you also go by strand count.
Theres a lot of companies that claim their wire to be 1/0 gauge and after looking at the strand count of the cheap wire, then compairing the cheap 1/0 gauge strand count to companies like stinger or rockford, you will notice that this cheap 1/0 gauge wire has the same strand count as a quality companies 4 gauge. The cheaper companys just put a bigger rubber insulator around the wire to try and fool you :mad:
If you got the extra 25 feet of 4gauge, and you dont want to spend money for 1/0 you might as well run it. It will result in less resistence giving you better electrical flow which is always a plus. So you wont be hurting your stereo or electrical system none, you will be making it more stable :)
I think someplace on the smd site there is a wiring guide stickied. I think its in the wiring forum. But it will give you a general rule of thumb for wiring sizes broke down into how many watts your running, and the length of the cable you will be needing, which results in what size wire you need.
Actuly it was a quick find. http://www.stevemeadedesigns.com/board/ind...?showtopic=1005
4 gauge: ~140 amperes
Class D (~70% efficiency) - <1400 watts
Class A/B (~50% efficiency) - <1000 watts
The average lenth of a power wire is around 18 feet. But say you need 30 feet, then id sugust stepping up to 2 gauge since the extra length in wire will raise resistance which means your amp is not getting the current it needs as fast as it needs it.
At least somebody nailed the length part of the equation..
think about a 10amp draw from 1000ft away.. shit it would need 1/0 for a 12v run.
Back to my hole.
p.s.
@ 18ft you are close to needing to run the other wire, if you have it run it to a d-block then go into the amp.
It wont hurt thats for sure.
  • Who's Online   1 Member, 0 Anonymous, 941 Guests (See full list)
