DC Sound Lab
I was not sure what stats change with the upgraded coils so im just double checking here first before i build the box.
I need the following for a 15 lvl4 w/ lvl5 coils
Qts
Vas
Fs
Re
Le
Xmas
Z
Qms
Qes
Spl
Pe
Bl
Dia
Sd
Thank you in advance for any and all help you can give me.
Edited by SleeperSierra
.ılı.——Volume——.ılı.
Min- – – – – – – – -●Max
Qts
Vas
Fs
Re
Le
Xmas
Z
Qms
Qes
Spl
Pe
Bl
Dia
Sd
corret me if im wrong but isnt it pretty much to the xl?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Qts
Vas
Fs
Re
Le
Xmas
Z
Qms
Qes
Spl
Pe
Bl
Dia
Sd
yes, but not exactly, it doesnt change xmax and some other stuff. its different i think, but only slightly.
edit: it might be the same as the xl, but with 500 more rms in a lvl 4 package.
Edited by I like kicker
its a lvl 4 motor with lvl 5 soft parts, not sure which exactly changes, but i run 2 on a AQ3500 just fine, 7 cubes
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Ugh..this confusion thing of the xl's is getting old. I don't understand why people call them lvl4xl's, when they're not..the xl's magnet is like 20 pounds heavier than the level 4
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
  • Who's Online   1 Member, 0 Anonymous, 5035 Guests (See full list)
