Robert8252 Posted February 18, 2011 Report Posted February 18, 2011 Just using those dimensions is over 9 cubes gross!! Why can't you get the port right? In Torres calc adjust your actual box size until you get around 7-8.5cubes gross and then put in the info for port size and length and sub displacement. 45s will be nice if you can but aren't needed. 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
BanginOnABudget Posted February 18, 2011 Report Posted February 18, 2011 Did your sub come with T/S parameters? if so, drop em, and i'll give you the numbers you wanna hear ;D im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!!
dugee81 Posted February 18, 2011 Report Posted February 18, 2011 next time you make a box, use torres calc. much more accurate as opposed to RE 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
Playa Named Joe Posted February 18, 2011 Report Posted February 18, 2011 a center port at the back, firing back. 8H x 14L and 32D. you have to make the port like a box, but gives you a little over 16 per cube for port area, and 6.9^3 before sub and bracing dis[placement. That should be perfect. should yeild about 32hz tuning 1994 Pontiac Grand Prix build
Sammitch0 Posted February 19, 2011 Author Report Posted February 19, 2011 wait im confused? 8hight how can I do that? if the subwoofer needs 8" alone for clearance? and 7.5-8cft? what?! for 1 18? Grand Cherokee Team Backwoods Bumpers DC 15" Level 3's /w 4 Coils Pioneer deh4200ub Pioneer 3-ways Pioneer Tweeters Pioneer GM-D9500F Audiopipe 1500.1D @ 14.4v Clarion Equalizer Knuconeptz Kollosus 0ga Knuconpetz Kollosus 4ga Coming Soon: 270xp / xs1200
Sammitch0 Posted February 19, 2011 Author Report Posted February 19, 2011 would someone throw the dimensions int he calculator and send them to me? i use the calculator i used it on this box, I just messed it up and didnt tune low enuff, I need help getting it or someone to explain to me a simple way lol im so confused Grand Cherokee Team Backwoods Bumpers DC 15" Level 3's /w 4 Coils Pioneer deh4200ub Pioneer 3-ways Pioneer Tweeters Pioneer GM-D9500F Audiopipe 1500.1D @ 14.4v Clarion Equalizer Knuconeptz Kollosus 0ga Knuconpetz Kollosus 4ga Coming Soon: 270xp / xs1200
xXxOuTLaWxXx Posted February 19, 2011 Report Posted February 19, 2011 The 7.5-8 cubes is before displacement. After you add the port and the subs displacement it'll drop to where you need it to be. Punch those numbers in as the gross volume and then play with the port size till you get your net volume of around 6 cubes and I would tune to 30-32hz "i'd rather die like a man than live like a coward" quoted from Tupac
mazdaspl Posted February 19, 2011 Report Posted February 19, 2011 What is the displacement of your sub?
Sammitch0 Posted February 19, 2011 Author Report Posted February 19, 2011 Dave gave me NO T/S paramenters man NOTHING im going off almost nothing and hes not around right now so I cant get them emailed ot me. nvm he didnt ugh I dunno guys I need massive help im thinking displacement is like .5 Grand Cherokee Team Backwoods Bumpers DC 15" Level 3's /w 4 Coils Pioneer deh4200ub Pioneer 3-ways Pioneer Tweeters Pioneer GM-D9500F Audiopipe 1500.1D @ 14.4v Clarion Equalizer Knuconeptz Kollosus 0ga Knuconpetz Kollosus 4ga Coming Soon: 270xp / xs1200
manofthehour Posted March 15, 2011 Report Posted March 15, 2011 I've never been able to use Torres Calculator, too many spaces to fill lol, I use http://www.the12volt.com/caraudio/boxcalcs.asp to get the volume and port length and so on... Try that if the calculator is confusing you... My stuff '06 Scion xA: -Alpine iDa-x100 -Alpine KTP-445 Power Pack -Polk Audio db6501 (front components) -Polk Audio db651 (back coaxials) -2 RE Audio SEX12D4s -Cadence F1200-1D - Custom box tuned to 33Hz - Kinetik HC1400 - 50 ft2 of Audio Technix sound deadner - Big 3 My photography page
