Cashdollar2009 Posted March 6, 2011 Report Posted March 6, 2011 Good stuff! I like to try to pick up as much as I can from reading then point things out like I would like things to be spotted and noted for me. I am digging your sketch-up skills though! Just make sure you take lots of pics! On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not.
Carroot1 Posted March 6, 2011 Author Report Posted March 6, 2011 Good stuff! I like to try to pick up as much as I can from reading then point things out like I would like things to be spotted and noted for me. I am digging your sketch-up skills though! Just make sure you take lots of pics! yes will do!
R3nOSlaPP Posted March 6, 2011 Report Posted March 6, 2011 nice job on sketchup man looks good Vehicle: 2017 Chevrolet Silverado High Country Electrical: 320A Singer Alt, (2) Limitless Lithium 15ah, Full Throttle FT680-48 Speakers: Stevens Audio SA 6 (ACTIVE), Audio Designs 3” Subwoofer: (4) B2 Audio XM 8’s Amplifiers: (2) B2 Audio Rage 2500.1, (1) B2 Audio Rage 1200.6 Processors: NavTv M650 (integration), Helix DSP Pro MK2 Silverado Build Log
Carroot1 Posted March 6, 2011 Author Report Posted March 6, 2011 nice job on sketchup man looks good Thanks its really easy to do once you get the hang of it
Ji553r Posted March 6, 2011 Report Posted March 6, 2011 You're actually using three common port walls (top, bottom, rear) therefore your net volume should increase a bit dropping your tuning and raising your port area. wow i cant believe it never occured to me once that if it bends to make the "T" that it turns into a 3 common port wall. thanks man i had things confused. I don't fuck around. I go from zero to I hope you die in less than 2 posts build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
Carroot1 Posted March 6, 2011 Author Report Posted March 6, 2011 You're actually using three common port walls (top, bottom, rear) therefore your net volume should increase a bit dropping your tuning and raising your port area. wow i cant believe it never occured to me once that if it bends to make the "T" that it turns into a 3 common port wall. thanks man i had things confused. ya i never would have thought of that. maybe torres should add that in his calculator
RAM_Designs Posted March 7, 2011 Report Posted March 7, 2011 Be sure to post some pics when you're finished. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
chevyhoe08 Posted March 7, 2011 Report Posted March 7, 2011 let see some pics. 2-18" Fi Btls 2-RF T2500-1bd box 14cu.ft after displacement tuned @ 32hz. Socal Box Designer/builder
