MACnonsence6 Posted March 8, 2011 Report Posted March 8, 2011 got my pair of baskets today for the se 12s im working on building im wanting to paint them red just wondering how i should go about paiting a 12 spoke basket and what paint is best to use I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
EclipseChris Posted March 8, 2011 Report Posted March 8, 2011 What makes you think its different than painting any other type of metal? i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
cc_audio Posted March 8, 2011 Report Posted March 8, 2011 ^^^ real helpful Anyway, wash them real good with hot soapy water and let them dry. Give them a quick wipe down with rubbing alcohol right before painting. Start with a few coats of primer and paint away in whatever color you want, rustoleom automotive primer and paint works just fine. Just remember to sand away the spider and surround landing so that the glue will stick when you recone them. It's all gone! The Celica Build Feedback If I buy something from you, DO NOT USE FEDEX!
MACnonsence6 Posted March 8, 2011 Author Report Posted March 8, 2011 so i shouldnt have to worry about sanding the orignal paint off. everytime i paint something it always comes out bad like my laptop i even primed it and the paint just peels off not flakes its like the paint is soft idk what i did wrong thanks for ur help though I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Superjay Posted March 8, 2011 Report Posted March 8, 2011 the primer will do that, but spray it with Bulldog before the primer to tack it up. I'd use a LPHF sprayer, but that's just me. I'd paint it like a car. Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
BlitZ Posted March 8, 2011 Report Posted March 8, 2011 you can use a adhesion promotor before you prime them... old set up Alpine IDA-X305S Memphis M-Class 4x6" Focal Access 6.5" Hifonics BRZ2100.1D 2x DC Audio Lvl 4 15's Big 3, DR44 Alt, Yellow Top http://www.youtube.com/user/SicNoma003
JaM Customs aka mprete Posted March 8, 2011 Report Posted March 8, 2011 you HAVE TO SAND BEFORE PAINTING ANYTHING!!!!!!! if you dont it will not stick well. 200 grit is what it needs to be. if it is smooth there is nothing for the paint to stick to and will flake off. the scratches from sanding give the paint a surface to grab on to.... sand.... prime .....paint..... 2001 dodge ram 2500 quad cab 5.9L V8 my build logs... dodge build http://www.stevemeadedesigns.com/board/topic/94914-mpretes-2001-dodge-ram-2500-quad-cab-build-log/ trik build http://www.stevemeadedesigns.com/board/topic/94447-trik-build/page__p__1298547__hl__trik__fromsearch__1entry1298547 box building thread- very cool designs (PICS!!!) http://www.stevemeadedesigns.com/board/topic/95713-2d-or-3d-box-pics/page__gopid__1318152entry1318152 i am a mechanic, pm me if you have questions or anything.
sprkn_ranger Posted March 8, 2011 Report Posted March 8, 2011 you HAVE TO SAND BEFORE PAINTING ANYTHING!!!!!!! if you dont it will not stick well. 200 grit is what it needs to be. if it is smooth there is nothing for the paint to stick to and will flake off. the scratches from sanding give the paint a surface to grab on to.... sand.... prime .....paint..... ^this Sanding first then cleaning very well with alcohol is a must. And sand in-between primer coats as well, then on the last primer coat, progressively sand to a high grit paper. And as said above, anywhere you need to glue the recone (spider and surround) to the basket make sure you are down to bare metal and it is CLEAN so it makes a good bond. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
