I'm planning to build a new box for my 2 Infinity Reference 860w's that I currently use in my dorm for music/movies. This will be my third "real" box I have built. My first box was the box the subs are in now and I completely messed it up when I built it but it still sounds good. I wanted to try some new things with this box and have been reading about kerfing and wanted to try it. Also, I liked the idea of kerfing all the corners of the port so this is what I came up with. the braces are 1" dowels and I might also put the left over bits of dowel in to brace the inside of the port but haven't decided yet. The box is tuned to... well... I'm honestly not quite sure. If it was a conventional port (but still kerfed at the end) it would be tuned to about 27 hz but I wasn't sure how to adjust it with the kerfed corners. I tried accounting for the difference in box volume and port volume and came up with about 25 hz after adjusting but I'm not sure if that is right. I was just going for as low tuning as possible since it will be used in my ht setup. Anyways, anyone have any opinions/tips/advice? Thanks.
i like the design but i think those curved pieces will be hard unless u can work with wood pretty good but i like it :)
I SCAM PEOPLE OUT OF MONEY... AVOID ME LIKE I AM AN AIDS INFECTED RETARD...
The basic concept of the curves is pretty simple and I'm pretty confident I can make them. Just wish I had a table saw. Would make it a million times easier.
Bump.
Anyone else have any ideas or suggestions or opinions? I am starting it on Tuesday if nobody answers but some more opinions from someone more experienced than me would be nice.
if you dont have a table saw how a re you going to cut all those kerf cuts
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I would suggest using pvc cut to make your corners. Kerfing small radius like those will be a bitch.
A skillsaw and a straight edge will get you the desired results for a kerf, but a tablesaw is a life saver.
Some one else said this already but it can be done just as effectively with a circle saw, it's just much easier with a table saw
Can you make a kerf with a 2" radius? I've seen 3" but not 2" while using 3/4" MDF. Also, that port opening is too close to the left sub.
I just checked the numbers and it would take 12 cuts about 1/6 of an inch apart which is about a blade width and a half apart so it could be kinda hard to do. I will prolly redesign the box tomorrow with 3 inch ports and see what it looks like. I think I will at least up the port opening to a 3 inch kerf.
If I did this, how do you attach the PVC to the MDF?
Sounds like an idea to consider but I'm not sure how to attach them and would it be a problem as far as strength?
  • Who's Online   0 Members, 0 Anonymous, 1074 Guests (See full list)
