well what are some tools you guys can recommend, i was putting my box in my mustang and it couldnt fit all the way through because of slight pecices where in the way, from the thing that behind the seats that makes them fold down and also some other ones 6inches past the box
Edited by KnockinthaStreetzof608
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
air saw.
air saw.
how much will a nice air saw cost me? and there any decent ones avaible without running it on air?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Sawzall and an angle grinder. It won't be as precise as an air saw but it will get it done and not require a compressor.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
you think its possible to get this tools rented or am i goin have to buy these?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
You can rent a 4 1/2" inch grinder at The home depot for like 5 bucks an hour or maybe less, and just buy a couple of cut-off wheels there about 2 bucks each you might need 2, if this is your first time using a tool like this i suggest buying some safety glasses and a pair of thick leather gloves. Also just a tip when you are cutting, cut very slow and hold that grinder real good, real good.!
Good Luck.
2-18" Fi Btls
2-RF T2500-1bd
box 14cu.ft after displacement tuned @ 32hz.
Socal Box Designer/builder
dont use a grinder. you will hate it. sparks flying everywhere inside your car. burning you randomly, putting pepper marks on fabric, etc. plus it takes longer. an air saw is pretty damn cheap at a harbor freight. i think mine was $15-20. saws-all will work but they are just bigger and harder to work with in a tight space. it'll definitely get the job done though.
Edited by skittlesRgood
x2 deffinatly dont want to use a grinder sparks in small areas suck
check out my build here and see what i did
i ended up using some snips and a jigsaw with metal blade
R.I.P!
(Nov-29-2009)
92 explorer
current build
and as for that second picture just hammer it in
R.I.P!
(Nov-29-2009)
92 explorer
current build
tin snips and a pair of balls
and big forearms
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
