Any easier way to get this damn thing on.
Close up of where I got it.
This is the only place I could slide it but I'm doing it alone. Any suggestions. There's no way itll go on a grooved pulley. I still can't get it on even with the tensioner cranked all the way down. I'm at the hobby shop on base and it closes in an hour. Help my fellow SMDers
i would assume your belt is too small if its not working. You should always set your belts up onto all the pulleys and then leave the tensioner as the last one you have to put the belt onto as it is easier to put a belt on the tensioner than it is to fit it over the other non-moving pulleys. What i do to cheat with getting the tensioner down all the way is to get a breaker bar and put that on my tensioner and get a strong piece of a metal pipe (i use a fence post) and slip that over the breaker bar and it gives you a ton of leverage and force and allows me to get the tensioner all the way up and slip the belt onto it.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
yea a bigger belt may not work. Idk bro i always just get a ton of leverage on the tensioner. Hell when i put a new belt on my envoy i had to put the tensioner all the damn way down to get the belt on and it moved 1/8 of a inch from where i had the tensioner fully pulled down.
hmm i really think they gave you the wrong size belt. shit happens in a warehouse. ppl are not perfect. lol. About how much length would you say you had when you fully depressed the tensioner to get that belt over the pulley for your fan? How many inches was it? I would assume maybe a inch or so. If its possible id see of you can go to autozone or somewhere cheap and get a test belt and see if it fits with it being an extra inch or 2 longer than the gatorback you have now.
Also, how tight is your belt on the engine since you bypassed a few of those pulleys?
ah ok. glad it works with the old one. What you could have done as long as you didnt have belt slippage was wear your new one in a little bit too. But if i were you id keep the new one with you at all times so if your old one breaks on you, you at least have a spare to get home with. I always keep a spare belt in my truck even though its only a single alt.
looks like 2 of the pullys arent even being used with the new belt, probably the wrong belt, just my opinion though ,, good luck
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
