Ed Explains Trippi's Hummer
Thanks man, that means a lot that you even took time to try to help me out. Now I just need to find a translator. lol
Translation, you need a shit ton more power wire. :trippy::pardon:
dammit this site needs a LIKE button..
you did what i was sorta thinking..more wire? or thicker and more wire?
i have a headake after reading that post..
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
I think addressing the power delivery to the amplifiers will be a larger factor than most think. The RF amps use unregulated power supplies - less voltage IN = less current IN. Since Power is the product of voltage and current this will be a big factor, considering 11.5 VDC is 20% less than 14.4 VDC. If I were doing this upgrade, I would document the following before I changed anything:
1. The nominal voltage available with the vehicle at idle with the audio system muted
2. The minimum voltage at the B+ and B- terminals of one of the sub amps over a 10 second blast of said Bass Mekanik track
3. The average voltage at the B+ and B- terminals of the same sub amp over the same 10 second blast of the same track
4. The maximum voltage drop between the B+ terminal of the same sub amp and the output stud of any alternator during this same time frame
5. The average voltage drop between the B+ terminal of the same sub amp across the same run during this same time frame
After you've measured #1, two good DMMs (one used for measurements 2&3, the other for 4&5) like Fluke 87s or 88s can capture all of this data in a single 10 second period. It's important to document this because you want a starting point. From there, you could easily factor this data as a percentage in a number of ways.
Ideally, modifications will be made so that the amplifiers will see 14.4 VDC (when measured across the B+ and B- terminals) even at maximum output. Factoring only the subwoofer amplifiers here, and assuming each can make 3,000 watts RMS into 1 ohm (common), the math would be as follows:
3,000 x 12 = 36,000 Watts RMS
36,000 Watts RMS / 64.5% amplifier efficiency* = 55,814 Watts Input (on sine waves)
55,814 x 50% Duty Cycle (music factor) = 27,907 Watts Input (music at clipping)
27,907 / 14.4 VDC = 1,938 amps of current
That's (6) 350 Amp alternators just to feed the bass amps. If I assume the length of cable from the alternators to the amplifiers is 20 feet and assume another 3 feet from the alternators to the frame and 7 feet from the amplifiers to the frame, this gives a net length of cable of 30 feet (not including the frame rail return path, which would have very low resistance). If I pull out my copy of Automotive Wiring and Electrical Systems (Hey, I refer to it too . . . LOL), and look at the chart on page 100, I can see that 1/0 AWG (as in cable that meets the American Wire Gauge specification) is good for about 140 amps (give or take a few) at 30 feet. This will require 14 runs of 1/0 AWG cable on both the power and ground side of things just so that the sub amplifiers can play music at clipping - this does not factor all those 1,000 watt 4-channel amplifiers nor additional batteries in the rear of the vehicle that require between 7 & 10 amps each to maintain a surface charge . . . That's a bunch of ring terminals to solidly affix to the ends of cables to minimize resistance . . .
Yeah, I'm guessing there might be some "gain" in addressing this. After this was addressed, I would repeat steps 1-5 from above and factor all as a percentage. If Step 5 / Step 1 > 5%, then you still have work to do, although below 10% the law of diminishing returns will certainly be a factor . . . consider where that is currently . . .
*found at RF's web site on the 2500-1bdcp @ 1 ohm - the 2500-1 may be slightly different.
Thank you,
even if your estimates are within a 10% +/- tolerance on the power wire amperage capacity, (due to wire type and purity, exact length, and quality of connection points) I believe there is certainly room for improvement, not just in power, but in cleanliness of signal and in reliability.
And as I stated before, with greater power flow, even the mids and highs will get louder, and sound even better.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
lol
true
Snafu is also saying to test before and after any changes to track gains and/or losses.
Testing at the source, and at the amp, and any connection/distribution or junction point in between will reveal your week points.
Ed Lester
ShowtimeSPL Host
My old Build Log
Wow, those 5 steps at the beginning had my head spinning, but then I understood the rest of the post... Odd, huh? Lol
Great explanation though, Snafu.
I like the oldschool one..
Current System: Stock 2011 Tahoe
Loud as F**K
Just kidding
Oh I forgot,
partial translation of Snafu's post also states that his book is an excellent source of information on automotive wiring.
Ed Lester
ShowtimeSPL Host
My old Build Log
Oh I forgot,
im looking on google now for it.
but say i would get confused real quick if i barley understand his post at all..
AMP: dc 9k @ 18v
Believe me, the book goes into GREAT detail. I own it, so I would know lulz
Nice job Snafu!! I can't wait for v2 ;)
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
How much and where can i get this said book????
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
I got mine from Amazon
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 6008 Guests (See full list)
